Earthing wiper motors
Discussion in 'New users start here - FAQ' started by Kass55, Apr 12, 2016.
  1. Kass55
    Kass55 Member
    PC support
    325Coins
    I read article about mandatory modifying wiper motors and since I am having trouble I opened up both my wiper motors, but can not see wire
    as it goes down through below plate, which held by 3 small alien screws, which I can't remove.
    I did test and the motor case is connected to + - somewhere inside unit.
    The question is...
    Do the motors have to be earthed ? or simply isolated ?
    My first version of 2DOF seat seamed to work with un-modified wiper motors,
    perhaps because the base & seat base was made of wood, therefore isolated from controller, power units and each other.
  2. RacingMat
    21,023Coins
    yes it's mandatory
    because with 2 motors connected to ground, when the Hbridge will drive one motor reverse and the other forward, the 12V and 0V will be connected together through the structure
    -> short-circuit!
    yes indeed
    • Agree Agree x 3
  3. Kass55
    Kass55 Member
    PC support
    325Coins
    Thanks for confirm
  4. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    You know how isolate mass?
    this manual by the forum ...
    I tube to drill the rivets did not come quite complicated screws to open
  5. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    This requirement is for AC motor only or also DC motor?
  6. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    We are talking about WIPER MOTORS 12V-24V DC here!!
  7. Kass55
    Kass55 Member
    PC support
    325Coins
    Yes, car or truck wiper DC motors.
    Follow the instructions (in FAQ section) to fix Earthing on wiper motors.
    I couldn't undo alien screws (which where damaged),
    so I got around problem by using wood to insulate motors from both base and platform, power supplies and the other motor.
  8. Mike-xu
    Mike-xu New Member
    Chile
    319Coins
    if just connect one motor to each MMs, is it need ground isolation?
  9. Kass55
    Kass55 Member
    PC support
    325Coins
    The problem is that wiper motors voltage is connected to body & arm of the motor,
    and the +- is changed / reversed each time the motor changes direction, effecting anything connected via metal.
    Should connect motor only via + & - wire, not via metal.
  10. RacingMat
    21,023Coins
    no! :confused:
  11. Guillemin
    Guillemin Member
    france
    302Coins
    You must find your happyness on this PDF
    Good luck
  12. choclo
    choclo Member
    Vienna
    388Coins
  13. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    this is not true. it is not mandatory . just run with 2 monster moto's each motor has its own board. this is what i have done and for over a year now , no issues.
  14. susocalfail39
    susocalfail39 Member
    GALICIA, ESPAÑA.
    50Coins
    the post is old but I was forced to put it in case someone reads it, it is almost obligatory to isolate the mass motors to avoid accidents, in the face of possible mistakes, I use the translator excuse me.
  15. noorbeast
    150,728Coins
    +11,018 / 55 / -2
  16. susocalfail39
    GALICIA, ESPAÑA.
    50Coins
    Oh sorry, when I hit the answer, I did not realize that I am in Spanish, I usually leave only one in English, sorry.
