Question Dual PC, Dual Game Engine(?)
Discussion in 'SimTools Pro & Entertainment Version' started by Mu-KwangKim, Oct 10, 2017.
  1. Mu-KwangKim
    South, Korea
    - 689Coins
    Hi all.
    Before the release of Simtools 2.2, we are looking for a way to get beyond the limits of the interface numbers.
    It can also be used to operate multiple motions simultaneously in the same motion ...
    When using a Dual PC configuration, I want the Game Engine to work on each PC.
    Or
    If you can control (?) The game engine of another PC by using Net Interface, it seems to be good.
    Please let me know if there is a way.
  2. yobuddy
    50,374Coins
    Maybe I'm missing what you guys are trying to do, but if you use a Interface that supports 6 axes, then SimTools can control 36 axes, or 6 full 6DOF sims.
    hard to imagine needing more?
  3. Mu-KwangKim
    South, Korea
    - 689Coins
    It seems I did not have enough explanation.
    Because you are using SCNs, there are not enough interface numbers.
    In 2.2, 12ch is supported. OK. But I am looking for a way to use it right away.
    If you can apply more than one IP setting in the game manager (Local & External IP), can you solve it easily?
    Anyway, is there any way I can use it right now?
    If there is no other way, I would like to use 2.2 beta version ...
  4. Mu-KwangKim
    South, Korea
    - 689Coins
    Added missing... ^^;
    Or a way to control the 'Game Engine' of another PC using the 'Net Interface' of 'Game Engine'....
