driving a tachometer R-type
Discussion in 'DIY peripherals' started by RodrigoOp, Jun 14, 2016.
  1. RodrigoOp
    RodrigoOp New Member
    Teacher
    Chle
    267Coins
    Este es mi tutorial para agregar un Tacometro R-type
    This is my tutorial to add a tachometer R-type
    El tacómetro maneja de 800 a 9500 rpm
    The tachometer handles 800 to 9500 rpm
    El código con un arduino uno:
    The code with a arduino One:
    int i;
    double cylinder = 4; // cyliner count for Tachometer.
    double divideUnit = 120; // 1/120 hz/(rpm * cylinder)
    double hzPerRpm = cylinder / divideUnit;
    int rpmtone;
    int pinTacho = 10;
    unsigned int rpm; // holds the rpm data (0-65535 size)
    unsigned int rpmmax = 10000; // retrieves from rpm live with minimum setting on initialization and Shutdown - Output
    byte rpmdata = 0; // marker that new data are available
    // INITIALIZATION
    void setup()
    // serial initialization
    Serial.begin(19200);
    pinMode(7, OUTPUT); //para el led que indica cuándo pasar el cambio
    //LED for indicating when the change happen
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
    // read input data
    readSerialData();
    // generate signal and send to tacho
    tacho();
    // Procedure: wait for complete trame
    void readSerialData()
    byte Data[5]={
    '0','0','0','0','0' };
    // parse the buffer
    if (Serial.available()>4){
    Data[0]=Serial.read(); // read command
    if (Data[0]=='M'){ // if rpm data
    Data[1]=Serial.read(); // store high byte
    Data[2]=Serial.read(); //
    Data[3]=Serial.read(); //
    Data[4]=Serial.read(); // store low byte
    rpm = NormalizeData(Data);
    rpmdata=1; // we got new data!
    Data[0]=Serial.read(); // re-read command
    if (Data[0] == 'Z' ){ // if Shutdown - Output
    Serial.flush();
    rpmmax=10000; // reset rpmmax
    if (Serial.available()>40) Serial.flush();
    void tacho()
    if (rpmdata == 1) {
    if (rpm>rpmmax && rpm<50000) {
    rpmmax=rpm;
    if(rpm>50000){
    rpm = 0;
    rpmtone = (int)(rpm * hzPerRpm);
    if(rpmtone > 320) {
    rpmtone = 333;
    // 697 max para mi tacometro a 9500 rpm
    //697 max for my tach at 9500 rpm
    rpmtone = map(rpmtone,0,333,0,675);
    if (rpmtone>495) // ENCIENDE EL LED CUANDO PASAN LAS 8000 RPM
    //LED LIGHTS WHEN PASSING THE 8000 RPM
    { digitalWrite(7, HIGH);
    }else {
    digitalWrite(7, LOW);
    if(rpmtone < 31) {
    rpmtone = 30;
    if(rpm>500){
    tone(pinTacho, rpmtone);
    else{
    noTone(pinTacho);
    rpmdata=0;
    // Function: convert Hex to Dec
    unsigned int NormalizeData(byte x[5])
    unsigned int result;
    for (int i=1; i<5; i++)
    if (x>47 && x<58 ){ //for xA to xF
    x=x-48;
    if ( x>64 && x<71 ){ //for x0 to x9
    x=x-55;
    result = (x[1]*16*16*16+x[2]*16*16+x[3]*16+x[4]);
    return result;
    la configuración:
    eso es todo.
    saludos
    Rod
    • Like Like x 5
  2. Ads Master
    Ads Master
  3. mrbeginner
    mrbeginner Active Member Gold Contributor
    What ever come in my way
    Finland Niinisalo
    20Coins
    Simple and clever! Do you use 12v transformer? How much transformer gives current?
  4. RodrigoOp
    Teacher
    Chle
    267Coins
    no, i use for this test a 3s lipo battery (12.4v full charge), but it's like 12v source
    i'm not sure how much Amps can handle. I not tested yet, when i have more time i can answer your question
    thanks
  5. mrbeginner
    Finland Niinisalo
    20Coins
    I try to install this in uno but it give me error. Can you tell me what i don't see.. problem.jpg
  6. Kirk
    Kirk Member
    Sr Software Engineer
    Texas
    15,033Coins
    2DOF, DC motor
    In the places you have just 'x', try 'x [ i ]' instead.
  7. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    561Coins
    3DOF, DC motor, SCN5, Arduino
    I would love a specific pin out diagram. Its hard to see from the video.
    I see the pin 7 and 10 and ground. Im not sure what is going to the tach from the other side. Power? Analog output? Thanks for the idea. Next on my build list!
  8. RodrigoOp
    Teacher
    Chle
    267Coins
    @mrbeginner : Replace with this, copy paste have troubles in the forum.
    sorry.
  9. RodrigoOp
    Teacher
    Chle
    267Coins
    @PiaMan a schematic for you.
    bye.
  10. RodrigoOp
    Teacher
    Chle
    267Coins
    @Kirk i paste a image, forum have some troubles uploading [ ].
  11. mrbeginner
    Finland Niinisalo
    20Coins
    thank you. I get it work. But first it take double rpm than the game show. I change double cylinder = 4 to 2 and then my meter work ok.
  12. PiaMan
    561Coins
    Thank you
  13. RodrigoOp
    Teacher
    Chle
    267Coins
    in my case 6 cylinder to get correct set up
  14. RodrigoOp
    Teacher
    Chle
    267Coins
    This code let you know rpm in your fisical tacho
    /* */ are coments
    int pin=10;
    void setup() {
    // put your setup code here, to run once:
    void loop() {
    /*delay(500);
    tone(pin, 50);// 1000 rpm
    delay(500);
    tone(pin, 110);// 2000 rpm
    delay(500);
    tone(pin, 160);// 3000 rpm
    delay(500);
    tone(pin, 210);// 4000 rpm
    delay(500);
    tone(pin, 265);// 5000 rpm
    delay(500);
    tone(pin, 330);// 6000 rpm
    delay(500);
    tone(pin, 410);// 7000 rpm
    delay(500);
    tone(pin, 495);// 8000 rpm
    delay(500);
    tone(pin, 600);// 9000 rpm*/
    delay(500);
    tone(pin, 747);// 9000 rpm
    bye
  15. mrbeginner
    Finland Niinisalo
    20Coins
  16. mrbeginner
    Finland Niinisalo
    20Coins
    I try it again and the problem is when your rpm goes under 1000 then the needle go crazy. it goes straight to max and if i press gas pedal it goes back to normal. Same thing both games Assetto and pcars
  17. RodrigoOp
    Teacher
    Chle
    267Coins
    i use this sketch to know the limits of your tacho
    int pin=10;
    void setup() {
    void loop() {
    delay(500);
    delay(500);
    under tone (pin, 34) my tacho have inconsistences
    search in upper sketch this line
    if(rpmtone < 31) {
    rpmtone = 30;
    change rpmtone with upper value like
    if(rpmtone < 31) {
    rpmtone = 34;
    then replayme
  18. mrbeginner
    Finland Niinisalo
    20Coins
    Thats the spot!
    Now it works like it should!:D
  19. RodrigoOp
    Teacher
    Chle
    267Coins
    good news
