Does go also with a Ps3?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by genocide, Apr 15, 2009.
  1. genocide
    genocide New Member
    I want built a motion chair.
    Does ' s go also with a Ps3? How works the chair . Use the chair the force feed back movents of the game? An how i became it into the chair?
  2. Fahim
    Fahim Member
    553Coins
    No consoles! uawhaha uahaha haahha :D
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Linux or consoles are not supported by the force sender. However, if you are a programming guru of either of these systems, you can create your own sender program. Licensing is a problem with the X-Box because M icrosoft controls the only API, not sure about the PS3.
  4. Fahim
    Fahim Member
    553Coins
    Dear sir,
    In the PS3 you can put you own operating system like Linux or Windows XP.
