DIY pneumatic cylinder advice
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Spart, Mar 29, 2020.
  1. Spart
    Spart Member
    Student
    Kauno kaimas
    229Coins
    DC motor, Arduino
    Hello everyone. Me and my friend are making chain driven racing sim, we only have pitch/surge and sway/roll axis, also traction loss( not finished yet), and we want to add heave. We figured out the basic concept we will use, its basicly 4 threaded rods that are driven by 2 motors (800W each) and all linked together by chain/belt (havent decited yet). I did all the calculations, we should get about 250mm/s speed, didnt really figured out how to calculate acceleration. But the main problem is that those two motors will need to lift heavy weight, rig with driver should be about 200-250 kg, in theory those engines should lift it but the problem is that it will lift slow and lower fast. So to combat that I decited to make pneumatic cylinder that would support about 150-200kg. Did the calculation, I should need 2-3 bar pressure and use 10 cm diameter pvc pipe as piston. I will also attach large air reservuar so the pressure wont change a lot during all piston stroke(25 cm). Have anyone have any experience in making airtight large diameter air pistons ? Iam not sure what kind of O rings I need to use to hold 3Bar pressure without any leakage, because fiting a compresor to compensate for piston air leaking is not an option. Pls help me
