Showroom DIY 3dof Dbox Style Rig with 4 x 750 Watt Linear Actuators 100 mm
Discussion in 'DIY Motion Simulator Projects' started by Ringorumble, May 10, 2018.
  1. Ringorumble
    Ringorumble Active Member
    190Coins
    Here is some Rallycross, Iracing . Daytona Long ...
    Lots of traction loss and roll, Pitch .. heave ... .. perfect for imitating beeing in the car :)
  2. Scott Vermeyen
    Scott Vermeyen New Member
    United States
    7Coins
    Great stuff, this is exactly what I'm looking at doing as soon as I move into my new property and can stretch my legs. A D-Box style rig that doesn't set me back a mortgage.
    Are there any further resources on the Arduino wiring? That's the one bit I'm not entirely sure of.
  3. Michael Hensen
    Michael Hensen Active Member
    C# Software Engineer
    Almere, Netherlands
    748Coins
    EDIT: Not read the intro well enough.. it is different!!! my mistake...
    I just leave the question as maybe somebody else reading has an idea..
    Great setup and a real good accomplishment.. !!!
    Can you tell me more about the Arduino code..
    I am running this https://www.xsimulator.net/community/threads/diy-d-box-style-for-vr-3-dof.11524/page-3#post-157101 now.. greatly the same configuration as you are running, although a different closed loop servo stepper and the way the frame is connected is different.. but qua setup nearly the same//
    But I am having a problem with the AccelStepper library.. the acceleration and deceleration gives me a grinding noise due to vibrations when running slow, no matter how high I set it.. I noticed yours are near quite..
    So please can you either share the Arduino code? or otherwise give me pointers on what I can change? A form of acceleration is needed otherwise the overvoltage alarm kicks in in my case..
    Would be really grateful.. right now it is loud beast, not the spindle but the accel/decal giving vibrations!!!
  4. Ringorumble
    190Coins
    Hi Michael, thanks :)
    All the Kudos go to Saxxon, he did the coding and ... get in contact with him .. i am just a happy guy which has the possibility to use his software and build actuators with his design .. Hopefully in the future more people get the opportunity .. The biggest problem is always that most time if you post it for free some guys rip it and go commercial .. and tell people they invented the seventh world wonder ..
  5. SeatTime
    28,370Coins
    The OP uses a AC servo motor similar to what many use in their DD wheels. Unfortunately not similar in controller/driver requirements to your stepper motor.
  6. saxxon66
    saxxon66 New Member
    323Coins
    The motor driver we are using is doing all the accel/decel caculation, so so need for a faster Micro controller.
    In your case, a 3.5 teensy could be used.
    There us a great lib, that can drive all of your motors with accel/deccel and many more options up to 300khz.
    Teensy 3.5 is 5v tollerant, so if the 3v is not enough for your setup, you ca go the open drain way.
    It is called TeensyStep.
    https://github.com/luni64/TeensyStep
    Hope that will help you.
  7. Michael Hensen
    Almere, Netherlands
    748Coins
    I have a teensy 3.5 so I will test the driver with a simple program first.. and I will for sure have look around.. Can you tell me what you mean with 'Teensy 3.5 is 5v tollerant, so if the 3v is not enough for your setup, you ca go the open drain way.' ?! I know it is 3.3 out on the PWM and therefor not sure if it would work, I remember I've tried but do a retest..
    Might need to go for some level shifter.. Not really home in the electronics/components part od diy :)
  8. saxxon66
    saxxon66 New Member
    323Coins
    Sure, 1st try your current setup. Ground from the controller and current from the output pin 3.3v.
    If your motor is turning, you are good to go. So anything above a certain voltage level, typicaly 2.5v will be seen as high.
    But if not, you can try to supply 5v from an external source and use your pins as input/ground. That is an open drain setup and can work due to the fact that the controller is 5v tollerant. Teensy 3.5 is.
  9. Michael Hensen
    Almere, Netherlands
    748Coins
    All working as expected.. without any tricks or 5v lines.. just straight on the pwm pins.. What a difference this makes.. the sound of the motor is different.. the speed is amazing.. what a power I now have.. I have to downtune everything..
    And this is based on Accelstepper and not TeensyStep.. I have to do some tests with that library as it looks to be better..
    Running all 4 motors on them instead of 2 per Arduino and still have a lot of power left!!
  10. Ringorumble
    190Coins
    Here are 2 Videos with sideview
    Formel Renault 2.0 / Line Rock / Iracing
    Heave Only
    Heave Surge Pitch Roll TL
  11. Ringorumble
    190Coins
    Had Some fun yesterday witrh lots of movement in the fiesta driving on Lime Rock in Iracing
    First Lap no Game Sound, second with
  12. AussieSim
    AussieSim Member
    Australia
    1,452Coins
  13. Ringorumble
    190Coins
    If you look at it you will see that they are different .. and no, it is a DIY Project, which will MAYBE be available to more people as time and tests go by :)
  14. Chris Indeherberge
    Chris Indeherberge Designer / dreamer
    Graphics Designer
    Belgium
    184Coins
    Are there any updates about the tests?
  15. Ringorumble
    190Coins
    Yepp, saxxon postet something over in the VR thread mentioned in the comments of my videos ...
  16. RaceRay
    23,839Coins
    Pinned on top of the DIY list. Definitely worth it. Thanks to @noorbeast suggestion
  17. saxxon66
    saxxon66 New Member
    323Coins
  18. Ringorumble
    190Coins
    • Like Like x 8
  19. misoswan
    misoswan Active Member
    1,000Coins
    3DOF, Arduino, JRK
    thanks very much
  20. misoswan
    1,000Coins
    3DOF, Arduino, JRK
