Bug Disappearing values at axis assigment
Discussion in 'SimTools Pro & Entertainment Version' started by Martyn, Apr 30, 2017.
  1. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Hello, anybody else having same issue?
    Got Simtools 2,0 PRO, set all axis assigment properly, but from time to time some setting disappears completely / change their positions (surge instead of sway and viceversa).
    Doing in all plugins (using FSX, AC, Dirt Rally)..
    Windows 10 64bit..
    150,686Coins
    +11,018 / 55 / -2
    By any chance do you have NL2? It does not always shutdown cleanly and that may mess with other things that are subsequently started.
  3. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Sorry for stupid question, but what is NL2?:)
    Edit: If you mean No Limits rollecoaster, then no, i do not have this one..
    Just AC, Dirt Rally, FSX and trying to War Thunder, but that one does not work for me at all:(
    150,686Coins
    +11,018 / 55 / -2
    Sorry yes I did mean Nolimits.
    In your settings do you use the same column for each axis no matter what the game?
    And can you check your running processes when it next happens and see if two games are running at the same time.
  5. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Yes one culumn = one axis, in every game..
    It seems to me that when i play (tune) dirt for example, the assetto settings change also.. Usually extra 1 disappears completely and sway changes column with anything else:eek:)
    That´s my dirt setting for example, at this picture there is sway insead of roll (did not noticed while i was capturing that img).
    https://www.xsimulator.net/community/proxy.php?image=https://s14.postimg.org/9yre02vkx/1.png&hash=56bf5ddfc9f172eb8b06e59635d25216
    I do not think it is even possible to run two games at the same time - i have everything on steam which i believe do not let run two games anyway..
  6. yobuddy
    50,334Coins
    @Martyn
    Sounds like a game did not shut down correctly, you could try this buddy.
    Navigate to:
    C:\Users\(your users folder)\AppData\Local\SimTools\GameManager\GameProfiles
    (appdata is a hidden folder, so your pc needs to have the setting to show hidden folder and files)
    Now simply delete everything in the GameProfiles folder so it is empty.
    Including the "LastUsed" and the "Profile" directory's.
    Now restart Game Manger and see if your good to go!
    (yes, you will need to re-setup any profiles you had in game manger, but its not to hard)
    Let me know how it goes buddy,
