Bug dirt rally 2.0 no motion
Discussion in 'SimTools DIY Version' started by absyfadhel1, May 22, 2020.
  1. absyfadhel1
    absyfadhel1 Member
    bahrain
    74Coins
    help i tryied every what you they said on this thread
    https://www.xsimulator.net/community/threads/no-move-with-dirt-rally.10704/
    but no motion...so its only work with network on simtools or can i use it with serial for arduino for examble (com3) ???becuase i tryied network nd serial but its same no motion
  2. Ads Master
    Ads Master
    108,861Coins
    Do you have a 32 or 64bit version of Windows and what patch path have you used?
  4. absyfadhel1
    absyfadhel1 Member
    bahrain
    74Coins
    i have 64 bit and i followed what you said and its the same this is the setting i use
    i tryied to use network for interface type but nothing move
    then i tryied the serial type
    but its the same
    Note: the serial type worked with all game i used exept DR 2.0
    this is the axis ajustment if you want it
  5. yobuddy
    31,861Coins
    We would still need to see screen shots of the Game Manger side of things, and one of the min/max numbers in Game Engines tuning center to really be able to help buddy.
    Take care,
    108,861Coins
    You don't need to change the Interface settings and @yobuddy is right, we need to see how you have configured Axis Assignments and the Tuning Center, please include a picture of the Tuning Center with the game running (you may need to have it in window mode).
  7. absyfadhel1
    absyfadhel1 Member
    bahrain
    74Coins
    this is my tunning center
  8. Daguru
    Kitchen installer
    Wales uk
    714Coins
    Check in your
    hardware_settings_config.xml or
    hardware_settings_config_vr.xml if you are using VR,
    found below
    C:\Users\*your username*\Documents\My Games\DiRT Rally 2.0\hardwaresettings
    and make sure that it has this line in there
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
    example
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" extradata="1" ip="127.0.0.1" port="20777" delay="1" />
  9. absyfadhel1
    absyfadhel1 Member
    bahrain
    74Coins
    so when i put this setting so i must use network on interface type or keep it serial?
  10. Daguru
    Kitchen installer
    Wales uk
    714Coins
    if you have movement on other sims then everything should stay the same just chack hardware_settings_config.xml for the line and if its not there copy it in and test see if it works then report back
    :thumbs
  11. absyfadhel1
    absyfadhel1 Member
    bahrain
    74Coins
    is this setting right? becuase nothing move until now
    and i tryied what you said but nothing good
  12. Daguru
    Kitchen installer
    Wales uk
    714Coins
    no sorry you misunderstand leave simtools settings as they are and in windows go to
    Documents\My Games\DiRT Rally 2.0\hardwaresettings and look for file called
    hardware_settings_config.xml open in note pad and look for the line
  13. Daguru
    Kitchen installer
    Wales uk
    714Coins
    hope this helps
  14. noorbeast
    108,861Coins
    Keep your Interface Settings as Serial.
