Dirt Rally 2.0 and FlyPT Mover
Discussion in 'FlyPt Mover' started by Aerosmith, Nov 19, 2025 at 13:46.
  1. Aerosmith
    Aerosmith Active Member
    self employed
    2,760Coins
    3DOF, AC motor
    We have problems with the Dirt Rally 2.0 source in FlyPT Mover. "Connect" has no effect, all variables show a zero value all the time while the game is running. And yes, we did the patches in the config file. The funny thing is that if we use the other source (Dirt Rally without "2.0") it patially works but some variables have exchanged or senseless values.
    First, I thought this was a problem of the new Mover (3.7.0.17) but it's the same with Mover V3.5.
    Any ideas what we need to do to make it work?
  2. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,620Coins
    The patch is different between both versions of Mover. Make sure you use the correct patch for each Mover version.
    In 3.7.x.x, press the pen button in the source to apply/remove the patch
    If it doens't work, try another port in the source and apply the patch again (remove/apply) to change the port
  3. Aerosmith
    self employed
    2,760Coins
    3DOF, AC motor
    Oh, indeed. There is a small pen button on the right side and a joystick button.o_O I haven't noticed at all, so far.:blush The buttons are so small they can be easily overseen. And I haven't found any mention in the docs. I'll try that out ASAP.
    But then there's still the question why it didn't work with the old Mover.:think Never mind...
