Der Simulator von RenoBoss
Discussion in 'DIY Motion Simulator Projects' started by RaceRay, Nov 20, 2006.
  1. RaceRay
    23,875Coins
  2. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    I have been busy!
    I just finished my last mods to my R'n'R.
    MODS:
    -made a larger the base-plate using thicker steel!
    -reinforced the arms and the pivotpoint of the X-axis!
    [​IMG] [​IMG]
    -made a new pedal-arm for the footrest
    -exchanged the original cylinders used on the X-axis for one SMC cylinder!
    [​IMG] [​IMG]
    -painted all the blank steel!
    -installed my new SMC valveblock
    -exhanged the 24 VDC 750 ma adaptor of the Momo FFB Red with a 30
    VDC 1500 ma.
    -installed USB 2.0 HUB onto the chair
    -wired and taped everything
    -changed front-speaker mounting positions
    -The making of the 10 turns extension-controller is until now a big failure!! :oops:
    -the reel is already machined out of aluminium but for now is seems impossible to align the Potentio + reel + bearing in one housing.
    Somehow it doesn't line up properly so I ended up with cracking the housing of the potentio! :cry:
    I used to built RC-models in the past so i went through some old parts!
    I found a Bowden-cable and did my best to implement it on the Y-axecontroller!
    [​IMG] [​IMG] [​IMG]
    Yesterday evening everything was finished and the setup of the Bowden-cable looks very steady!!
  3. Snaipa
    Snaipa New Member
  4. minoa3000
    minoa3000 New Member
    1Coins
    asks
    hi RENOBOSS (fantastic machine)
    in your machine . en the block of valves haves in the picture un ask.
    what thas namber 1 . silencer?
    and number 2 . as it is called? . is necessary this piece?
    thanks ( it pardons by my English)
  5. Renoboss
    297Coins
    2DOF, SCN5
    1= exhaust valves noise/pulse damper
    2= central valve body block.
    With this setup you have 1 air input for all the 4 valves and 2 exhaust for all 4 valves.
    I think it's nice and clean.
  6. Renoboss
    297Coins
    2DOF, SCN5
    This weekend I modded the pots (used the original 50 Kohms) of the RNR-board. Connected them directly to pin 2 + 3 of IC3 (http://www.x-simulator.de/de/hardware/a ... -poti.html).
    It seems to be faster and more precise!! still it's not all I want.
    Futhermore I will try do make the 3 speed / 4 valves setup !
    I'll keep you informed !!.
    For anyone interested the chair is for SALE !! (PM me ! )
  7. RaceRay
    23,875Coins
    Hi Reno,
    why do you want to sell that great chair. Why don´t you modify your chair to 3 speed / 4 valves setup ! ?
    regards, René
  8. Renoboss
    297Coins
    2DOF, SCN5
    Hi Rene,
    Like Egoexpress i would like to go Frex-style !
    Using the nice aluminium-profil systems! so it's easier to move pivot-points etc.!
    It's fine by my wife , only first the Old Thing out !
    and I have to be honest , for the space it's better !!
    As you know , I was here from the beginning.
    With GTR / GTR-2 , Race'07 & Rfactor i definativly go for race setups.
    FSX gives to much stress on my P4-system (3,2 GHZ / 6800U AGP) and I don't want to upgrade for now just for FSX.
    I 'll post this weekend in Buy/Sell forum!
    Modifications:
    -enlarged the base
    -new chairframe with racechair
    -enforcements of all the the arms
    -new SMC cilinders (total of 4x , with currently 3 used)
    -SMC controlvalves (4x 5/3 centre closed) on 1 backplane
    -Velleman USB controlboard (including all the mods) connected to
    -Velleman relaisboard
    -movementcontrol upgraded to bowdencables on original potis
    -including the 17 CRT screen
    -Also with the 2 original cylinders
    -the original rnr-board (partly demolished for parts)
    -and original chair
  9. XRiccardo
    XRiccardo New Member
    1Coins
    Can you help me?
    Can you share image of your detailed outline of the connections?
    from the Velleman USB controlboard to Velleman relaisboard, to valves and to cilinders?
    :sos:
    Best Regards!
  10. Renoboss
    297Coins
    2DOF, SCN5
