Question dc motor for ffb
Discussion in 'DIY peripherals' started by musk, Jan 3, 2020.
  1. musk
    musk New Member
    67Coins
    Hello everyone, I have such an engine, is it suitable for steering?
    The direct current DC motor with a hollow anchor DPR-42-F1-03 is intended for use as power motors and for driving various mechanisms of short-term, repeated-short-term and continuous operation in industrial automation equipment, telemechanics, radio electronics.
    Electric motors of the DPR-42 series are produced according to the technical conditions OST160.515.007-74.
    Engine designation structure:
    DPR-42-F1-03
    • DPR - an electric motor with a hollow rotor;
    • 42 - dimension number;
    • F1 - with flange mounting and one output end of the shaft;
    • 05 - execution according to the nominal data.
    Technical characteristics of the engine DPR-42-F1-03:
    • Supply voltage, V ...... 27
    • Rated power, W ...... 2,3
    • Rotational speed, rpm ...... 4500
    • Rated torque, mN * m ...... 4.9
    • Starting torque, mN * m ...... 12.8
    • Current consumption, A ...... 0.2
    • Starting current, A ... 1.15
    • Coefficient of performance,% ...... 43
    • Warranty hours, h ..... 2500
    • Weight, kg ...... 0.15
  2. Chris_Beeves
    2,064Coins
    I guess it’s usable, but it is very very weak. 2,3W will not give you much feedback. As a reference, I think the entry level Logitech Driving Force GT has a 50-60W motor.
