Dc motor driver advice
Discussion in 'Motor actuators and drivers' started by Gadget999, Jan 8, 2020.
  1. Gadget999
    12,353Coins
    I have started building a 6dof
    From what i can make out the options for a dc motor driver are
    Mmo - lots of them fail
    Sabretooth - good reviews
    Jrk from pololu - good reviews
    Ibt-2 - i use them for a Dc dd ffb wheel with no issues
    Any suggestions greatly appreciated, I dont want the drivers to be a headache or overly expensive
    EDIT
    in the end i ended up using these - very powerful easy 100 amps
    https://www.ebay.co.uk/itm/100-A-Hi...371961?hash=item1c46b55039:g:WB4AAOSwPe1UI4ao
    154,735Coins
    +11,213 / 57 / -2
    Sabertooth have until now been the most common in 6DOF builds, but of late there has been a move to servo powered actuators and rigs, using @Thanos controller.
  3. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Love my JRK's, but when you blow one (which I've done by overloading it with too extreme motion) it is an awfully expensive problem.
    For my next build I'm planning on going with MonsterMoto clones. They are so cheap that even if the quality control isn't great on some of them I can have a stack of spares ready to go and I would still save money. Plus I'm pretty comfortable working with Arduino's.
    I'm also planning on adding some current monitoring to my next build so I can see how hard I'm pushing my motor drivers.
  4. Thanos
    Electronics Engineer
    United States
    2,925Coins
    Thats right. because its cheaper to use servomotors now, considering the cost for similar power DC motors/ hbridges/powersupplies etc...
    If you are after a 6DOF platform build with rotary actuators, a good cheap combination will be these (can work on 110v/220v):
    -750W AC Servo Motor Drive Kits NEMA32 80mm, AASD-15A direct replacement: https://www.aliexpress.com/item/32983137811.html
    -Matching 50:1 planetary gearbox: https://www.aliexpress.com/item/32835293950.html
    Example 6DOF that is using these parts on the link above:
  5. Gadget999
    12,353Coins
    i found a clone of them here -- https://hobbycomponents.com/shields/462-monstermoto-compatible-high-power-motor-shield
    i am thinking i may use 2x ibt-2 on each motor - again they are cheap
    is it possible to blow a sabretooth driver ?
  6. Gadget999
    12,353Coins
    Right now i have DC gearmotors - do you have a solution to drive a DC brushed motor ?
  7. cgodwin
    Engineer
    Eugene, Oregon
    2,478Coins
    It looks like those are over $350 USD for each motor/gear reduction. For a full set of 6 that is well over $2,000 USD. Not what I would consider cheap.
    The 1/4 HP 12Vdc geared motors I used were just $60 each, plus under $30 total for a power supply and MonsterMoto driver. Not as much power, but $90 instead of $350 is a big difference. Unfortunately the motors I used aren't available right now. I should have bought as many as I could get when I could. It does look like DC motor prices have gone up, so it would take some hunting to find something high powered and cheap.
  8. Thanos
    United States
    2,925Coins
    Actually the price is right... you have 1/4hp power, the AC servomotors are about 1HP power... do the math. :nerd
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    To be honest
    You cant compare a brushed dc motor with a ac servo motor
    With luck you get a 3000 hour lifetime with a brushed dc motor and with a ac servo its all in the motorbearings EU brands talk about a 30000 hour lifetime and a 20000 hour lifetime for a planetary gearbox is nothing special
  10. Gadget999
    12,353Coins
  11. Peter24
    Peter24 New Member
    24Coins
    2DOF, DC motor, Arduino, JRK
    In JRK we can easy control current parameters. Is it possible the same in Arduino+MM ? Please explain.
  12. Gadget999
    12,353Coins
  13. cgodwin
    Engineer
    Eugene, Oregon
    2,478Coins
    The MM has a current sense output that can be read by the Arduino. The current can then be shown on a display by the Arduino. I also have a stand-alone current display that could work with any motor drive. All stuff I've planned but not actually wired up yet. I haven't blown a JRK in a long time so I'll leave those alone for now.
