Convert SCN5 150mm to 100mm
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by alejandro2lanz, Apr 22, 2021.
  1. alejandro2lanz
    alejandro2lanz Lanz
    San bartolome
    118Coins
    2DOF, SCN5
    Hello, I have working with very good results, a colpick with two 100 mm SCN5 actuators, mounted on the front, with a system of levers that new the complete colpick, pedals and steering wheel.
    My question is, I have two more than 150 mm actators, I wanted to put one as loss of traction, with that I have no problem. But I also wanted to put another one on the back of the colpick, as support
    of the two forwards.
    I changed the programming and I put the one for the 100 mm SCN5, with the scn5 utility it works fine, it only travels the 100 mm.
    But when I hook it up to Simtools and it does the centering it does the full 150mm travel
    Is there a way that this actuator does not center, or makes it 100 mm?
    153,914Coins
    +11,154 / 57 / -2
    Have you tried axis limiting in SimTools?
  3. alejandro2lanz
    alejandro2lanz Lanz
    San bartolome
    118Coins
    2DOF, SCN5
    If I have changed him.
    And that is effective, already once inside simtools,
    But on simtools boot it still behaves like a 150mm actuator.
    If there was a way for that actuator not to focus, it would work fine
