Continuous rotation
Discussion in 'DIY Motion Simulator Projects' started by aparecido, Nov 15, 2023.
  1. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    Can someone help me? When I turn off the simtolls, the motor continues to rotate, it does not return to zero.
    154,412Coins
    +11,181 / 57 / -2
    Can you please let us know what is all the hardware being used, what code is being used, and post pictures of all of your settings.
  3. Mario_Grao
    Mario_Grao New Member
    mechanical engineer
    Grado, Asturias, Principado de Asturias, ESP
    79Coins
    Hi!
    I had a similar problem in one of the motors and it was motivated by a wrong welding in pot´s wiring.
    Change one pot by the other (if the secod one works fine) and if the problem goes away , you got it¡.
    Good luck¡¡
  4. aparecido
    BRAZIL
    - 51Coins
    Thank you very much for the information, I will check it out.
