construct flight simulator . Help me
Discussion in 'Electronic and hardware generally' started by massimofarinelli, Oct 9, 2015.
  1. massimofarinelli
    massimofarinelli Member
    automation
    italy
    501Coins
    Hello everyone , I am trying to design a flight simulator .
    I would like to get some advice on how to start and what materials to use .
    thanks in advance to all those who will help me .
    • Optimistic Optimistic x 1
  2. massimofarinelli
    automation
    italy
    501Coins
    .... I forgot, I would use the platform that is Arduino , as I know him pretty well .
    configuration , lavorrei make 3-axis "pitch , roll , yaw" , to make more realistic the simulator .
    if you have any ideas or suggestions , I'm all ears .
  3. Riccardo
    Riccardo New Member
    Deruta
    33Coins
    DC motor, AC motor, Arduino
    Hi massimo
    150,704Coins
    +11,018 / 55 / -2
  5. massimofarinelli
    automation
    italy
    501Coins
    thanks for the help , yet I do not know where to find useful info for me .
    150,704Coins
    +11,018 / 55 / -2
    You really need to spend some time going over existing member builds and then formulate a plan of what you would actually like to build and post a picture of it here. That way members are in a position to give advice about materials and what motors and other hardware may be needed.
    These are different approaches to 3DOF with heave, or under seat heave here, under frame heave here, or my compact simulator with assisted heave here.
    Arduino code and information is here: http://www.xsimulator.net/community/faq/arduino.6/category
    Monster Moto driver options for Arduino here: http://www.xsimulator.net/community/faq/motor-driver-for-arduino-compatible-controller.11/category
  7. massimofarinelli
    automation
    italy
    501Coins
    ok , thanks for the link , the system that you have done, is like what I had in mind .
    the material available to me is :
    3 engines 24volt 165Watt , with gear 100 : 1 .
    Arduino boards of all types .
    Will ........ for now so much .
  8. massimofarinelli
    automation
    italy
    501Coins
    as soon as I can , I will post pictures with the engines described above .
  9. mgill4bu
    mgill4bu Member
    156Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, Joyrider
    That would be helpful, We built a sim from the joyrider design with some modified parts for around $800 without having any parts before costs.
  10. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    What is the result so far? Any progress u had ?
  11. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Use metal. Use Bolts. Use Motors. Use Power Supplies. USE THE SEARCH FUNCTION.
