Connection Interrupted
Discussion in 'New users start here - FAQ' started by rainy_august, Sep 5, 2011.
  1. rainy_august
    rainy_august New Member
    Hi all,
    I'm using 2PCs for my X-Sim and I'm facing the problem of connection interrupted during sending data from sender to profiler. While sending the game data from sender to profiler, about every minute then profiler shows not connected for few seconds. After that it connects again. Is that normal or because of network? If I will try to connect not through with wireless and try with Modern or linksys router, how should I connect it between sender PC and profiler PC?
  2. RaceRay
    23,875Coins
    Do i understand you right? You are connected through wireless? You should connect in any case both pc´s only via wire, as the latency and droped package frames are more when you use wireless ethernet.
    If you use a router, there is nothing special you have to take care. Just plug in regular ethernet cables in two open ports, and it works.
  3. rainy_august
    Yes, I'm now connecting through wireless. And thanks for the reply. I'll try to use with a router. :)
