value1
Codemasters F1 2018 plugin 2.0.1.0
SimTools plugin for Codemasters F1 2018
  1. value1
    14,258Coins
    Codemasters F1 2018 plugin - SimTools plugin for Codemasters F1 2018
    • Winner Winner x 5
  2. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
    @value1
    Thanks, perfect.hug:
    Just download it. Give it a try later this day.
    Let you know if anything strange happens.
    Update:
    Just had a run and everything is like it has to be.
    Only a little modification in the tuning center. The movements was a little too hard for me.
    But that's like normal.
    Thanks again.
  3. JohnCrichtonFR
    JohnCrichtonFR JohnCrichtonFR 5 DOF Gold Contributor
    Maintenance Technician
    22Coins
    4DOF, 6DOF
    Thank you, it's perfect, but the forces of the default settings are too strong, I have make 80 % instead of 100 %.
  4. alexdraco
    alexdraco Member
    278Coins
    Ciao,
    Great work!!!
    Grazie.
  5. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    Thank you very much for this plugin
    merci beaucoup pour ce plugin
  6. Wiseman1
    Wiseman1 New Member Gold Contributor
    Netherlands
    - 56Coins
    Thank you very much!:cheers
  7. BlazinH
    16,692Coins
    Learn how to use the tuning center to adjust to your preference.
  8. value1
    14,258Coins
    I think this is exactly what he did ;)
  9. JohnCrichtonFR
    22Coins
    4DOF, 6DOF
    Yes, that's what I did… I'm not a noob :D
  10. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    thank you very much
    I will test this today !!
    hug:
  11. BlazinH
    16,692Coins
    Sorry. :thumbs I thought you meant you set the main level % to 80 in game manager.
  12. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Thank you! I was hoping for this plugin! :thumbs
  13. schneemann
    schneemann New Member Gold Contributor
    Austria
    153Coins
    Thank you so much :thumbs
  14. SEHATanguy
    SEHATanguy Member
    Belgium
    96Coins
    Thank you! Works great here
  15. Adrian-33
    Adrian-33 New Member
    123Coins
    Thank you. Does it working with udp? Because my game is not on the same pc than simtools.
  16. JohnCrichtonFR
    22Coins
    4DOF, 6DOF
    However, in turns, the simulator does not look on the right side, the settings must be done in the pugin because no other way to reverse it.
  17. BlazinH
    16,692Coins
    If you mean what I think this is a simple fix but I don't want to offend you because a non-noob would already know how.
  18. JohnCrichtonFR
    22Coins
    4DOF, 6DOF
    So, why I have not any problems with all games plugin and I have just this problem with this plugin ? You who know everything a priori. Do you really think you understood what I meant or you're still completely missing the plate? I want just help all to post here, so, if you just make fun of it without giving a concrete answer, it does not help ...
  19. BlazinH
    16,692Coins
    It appears you are offended anyway so I cant win. Do you mean it banks the wrong direction in turns?
  20. JonBakhol
    443Coins
    I don't understand your "look on the right side".
    I tried this plugin, and it seems everything is okay....can you explain.
    Grt
    Bakhol
