Cockpit!!! Done!!
Discussion in 'DIY Motion Simulator Projects' started by leandroter7, Oct 27, 2009.
  1. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    Hy fellows
    I already finish my project, the name is TERCETREXXX :D
    [img600px]http://i643.photobucket.com/albums/uu159/leandroter7/cock.jpg[/img600px]
    Please, comment my project! i need feedbacks!!!
    With best regards
    Leadnro Tercette
  2. frouenque
    frouenque New Member
    Embedded software engineer
    Paris
    236Coins
    Re: Brazilian Cockpit!!! Done!!
    Very beautoful, very clear, but the weel support semms lite :S
    Great job ;)
    • Ale.rar
      File size:
      161 KB
      514
  3. Fahim
    Fahim Member
    553Coins
    Very nice. You have alot of angle on the actuators. You should tell us how it feels. Maybe post a video on youtube :) then put in this thread.
  4. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    Regarding the angle, i follow the Ledfoot opinion. Seems the actuators works without strees, the range decrease a litle bit, i fell it's more confortable now.
    this is my video on youtube : http://www.youtube.com/user/leandroter7 ... QsEh1jVPaQ
    bye
  5. sn4il
    sn4il New Member
    2Coins
    Very nice clean build.
    Are the aluminum profiles 40mm or 1.5? Is your sim sturdy enough?
    I'm about to order some profiles.
    Thnx
    sn4il
    • IL-2.rar
      File size:
      283.3 KB
      508
  6. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Great job leandro. You'll be glad that you took the time to test and find the optimal actuator angle and seat CG point for your rig using Bernard's test procedure.
    Sn4il,
    I used the 40x40mm lite profiles in my setup and it is very sturdy. You should have no issues.
    ....Mike
  7. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    me too, 40x40 lite
  8. ne02005
    ne02005 Member
    Argentina
    105Coins
    Very nice. What is the aluminium name or part number ??? I can´t get it...
  9. sn4il
    sn4il New Member
    2Coins
  10. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    that's it!
  11. ne02005
    ne02005 Member
    Argentina
    105Coins
    Thanks, I´ll try to find it in ARgentina, thanks again!!!!
    I find it!!!!
    Thanks a lot!
    Is very expensive!!! 40x40 cm x 1meter = U$S 25
    Can I use 30 x 30 ??? It will support the weight?
    What do you think?
  12. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I would go with the 40 x 40 lite if you can afford it. I've not seen anyone built one using the 30 x 30 so I'm not sure how that would hold up. If using the 30 x 30, make sure you properly reinforce the area that connects the actuators to the seat platform.
    ....Mike
  13. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    I imagine before start built, 30x30 is possible, but is not. Like ledfoot told, you need a strong base to suport the seat and the actuators. If you want save some money, use lite profile. 30x30 you can use for shift base also keyboard holder and wheel stand. For nexts cockpit, i will built in 40X40 heavy.
  14. mrpio
    mrpio New Member
    You must remember that all Frex cockpits are made of 30 mm. They do bend quite a bit, especially the steering wheel support, but they do the job of supporting the whole thing without a hitch.
  15. egoexpress
    the pic disappeared...
    regards
  16. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    sorry, i forgot to upload news pic, i will do this
    tks
  17. Silly(c)One
    Silly(c)One New Member
    ex-Web & Industrial Dev/Sysadmin
    Brussels, Belgium
    327Coins
    Up ! (we want pics ;))
  18. Muzza
    Muzza New Member
    Sunshine Coast Australia
    Save yourself some money and build your rig out of 40X40X3mm Aluminium box tubing. The only benefit to 80/20 T-Slot is if you are constantly making changes and adjustments to your frame work.
    My frame is more than stiff enough with the use of this profile and the entire cost including triple screen frame was only $350+/-25
    To memory I used 13 metres for the rig and 6 mts for the monitor frame. I made all my own brackets from 40X40X6mm Aluminium angle and bolted the frame together with M8 bolts. It took a while longer granted, but saved me a hell of a lot of money compared to 80/20 which was $244/2.4 metre length!!!
