Cluclu : 2DOF Arduino / Smolka 24V + Dashboard
Discussion in 'DIY Motion Simulator Projects' started by Cluclu, May 26, 2015.
  1. Cluclu
    Cluclu Member
    443Coins
    Hello everyone. Here I start creating a 2DOF simulator to learn the basics of programming already see what happens in sensation.
    I have now ordered all my equipment and I expect the package to get started
    So the equipment for the project:
    - 2DOF :
    1 Arduino Uno r3
    2 Smolka 24V
    1 Sabertooth 2X32
    1 24V 20A power
    2 10k potentiometer without mechanical stop
    4 female ball tip
    - telemetry:
    1 Arduino Uno r3
    1 8 digit 7-segment display
    - Dashboard
    1 IPAC 2 Encoder
    30 pushbuttons
    1 hand brake
    1 sequential shifter
    1 G27 modified (350mm steering wheel)
    Excuse me for my English way , I'm French ;)
  2. ascertif
    ascertif New Member
    france
    464Coins
    Hi, good luck for jour project.:thumbs
  3. RacingMat
    21,027Coins
    welcome Cluclu!
    good project :thumbs
    Can you share the URL of your potentiometers without stop, please?
  4. Cluclu
    Cluclu Member
    443Coins
  5. francois38200
    francois38200 Member
    vienne
    195Coins
    good luck cluclu :cheers
  6. Cluclu
    Cluclu Member
    443Coins
    Thank you very much François :cheers
    150,950Coins
    +11,025 / 56 / -2
    Can you post a drawing of you planned design, it does not need to be fancy, a photo of a hand drawn idea would do. That way members can give advice.
  8. Wanegain
    Wanegain Active Member
    Bruxelles
    1,998Coins
    Welcome and good luck!
  9. Cluclu
    Cluclu Member
    443Coins
    Oui je mettrais un plan approximatif ce soir
    Yes I would put a rough plan tonight
    Merci Wanegain ;)
  10. Cluclu
    Cluclu Member
    443Coins
    Bonsoir, voila la première esquisse 3D du projet. La suite demain soir normalement.
    Good evening , here is the first 3D sketch of the project. Following tomorrow night normally.
    [​IMG][/quote]
  11. Cluclu
    Cluclu Member
    443Coins
    Réception ce jour de la carte IPAC 2 V2015 pour le futur DashBoard
    Reception date of the IPAC board 2 V2015 for the future DashBoard
  12. RacingMat
    21,027Coins
  13. Wanegain
    Bruxelles
    1,998Coins
    Th most expensive will be the push buttons :eek:
    but you can do something very cool with that !
  14. Cluclu
    Cluclu Member
    443Coins
    J'ai trouvé sur Ebay des poussoirs pas cher. Et oui ça me laisse la possibilité de mettre toutes les affections de Project Cars sur le tableau de bord
    I found on Ebay cheap buttons. And yes it leaves me the opportunity to put all Project Cars affections on the dashboard
  15. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Can't post links but check out Aliexpress for pushbuttons, ordered 15 same as posted above me for 4,95 shipping included and received within 10 days :)
  16. Cluclu
    Cluclu Member
    443Coins
    Réception ce jour de mes leviers et des cartes pour l'affichage du dashbord
    Reception date of my shifter and maps for displaying the dashbord
  17. Cluclu
    Cluclu Member
    443Coins
    Bonjour tout le monde, j'ai reçu mes boutons poussoirs et j'ai récupéré mon volant. Mes moteurs devrait arriver demain ou mercredi. Il faut que j'aille au magasin de bricolage acheter du médium en 18mm pour fabriquer la structure ce weekend.
    Hello everyone , I received my push buttons and I got my driving. My engine is expected to arrive tomorrow or Wednesday. I have to go to the hardware store to buy the medium 18mm to make the weekend structure.
  18. RacingMat
    21,027Coins
    de la sciure en perspective ! ça va avancer !! :)
    some sawdust in perpesctive!
  19. Cluclu
    Cluclu Member
    443Coins
    Ho oui ça va scier ! J'ai préféré attendre d'avoir tout le matériel avant de commencer les découpes car je ne sais pas trop comment fixer mes moteurs. ça sera plus simple en les ayant sous la main que d'imaginer leur emplacement.
    Oh yes it will sawing ! I preferred to wait until all the material before starting the cut because I do not know how to fix my engine . it will be easier by having them on hand to imagine their location.
  20. Cluclu
    Cluclu Member
    443Coins
    Réception ce jour du colis avec les moteurs, alimentation, sabertooth, arduino etc
    Reception date of the package with motors , power supply, sabertooth , Arduino etc.
