Clarification on x-simulator system
Discussion in 'SimTools compatible interfaces' started by alex92010, Jan 14, 2012.
  1. alex92010
    alex92010 New Member
    Good evening everyone, I'm new in the world x-simulator, I'm a little confused in the system programming and recording of the axes of my simulator.
    I have 2 wiper motors but I have no idea how to connect to my computer.
    The purpose of my simulator is to simulate a moving video, so I only used the program videomotion plugin, although I know that everything is configured using the Force to use profiler and I do not know, someone could tell me to use electronic materials, where to buy and how to program the system to emulate video?
    I have a joystick for movement, even if I have not configured anything.
    I am Italian, I apologize for the translated lexicon.
    Greetings, alex92010 :sos: :sos: :sos: :thbup:
  2. bsft
    OK, I am not sure of how to get it to work on the video plug in, but as for motor controller hooking up, the easiest option is the Pololu JRK 12v12 http://www.pololu.com/catalog/product/1393 , one usb cable and 7 wires. One per motor. Several of use use them to great success with car wipers, winch motors, and golf buggy 12v motors.
    pololu-jrk-12v12-t2697.html refer to this post, read ALL the pages.
    Any other questions, just feel free to ask.
  3. alex92010
    Thank you very much, but there is something less expensive? even larger .. is really amazing how these things make you pay!
  4. bsft
    Cheaper? Not sure. I spent several months deciding myself. I was going to go down the K8055 + relays path like Bigtalltim, but the headache of setting the board up was not my idea of fun (sorry Bigtalltim).
    There is the Tronic card, if you wish to make the PCB and source the components and sort the issues around what I have read about it (look through any post relating to AMC, tronic). They are cheaper in cost to build apparently.
    Hence going the jrks. Many people here will tell you they are the easiest to set up, and handle more power than actually specified. So for $100 per motor, they are quite cheap considering the abuse a few of us give them. I run mine at max current with no issues (yes 30 amps). I run heatsinks on the big chip and fans on the boards, and they work just fine .( Thanks Eaorobbie).
    Apparently, Pololu are developing a 12v 50 amp jrk, but this is a few months off yet.
    Just holler for help as you need it.
    Cheers, David.
  5. alex92010
    I found an I / O Output controlled by synaptrix 8-bit parallel port.
    I have a computer so new, so I have the parallel port .. can you tell me where can I buy it? Thank you.
  6. bsft
    What board might you be planning to use?
  7. alex92010
    The problem is that I do not know the name!
  8. alex92010
    this too is a model I also know the name but I do not know where to buy it .. and I see no USB or serial port to connect to the computer ..http://www.youtube.com/watch?v=xe2v6zZ7 ... re=related
    it may take an adapter but I do not know where to find it, I do not know how to configure it .. In short I'd need a real straight at a price not too much .. such as with a card I / O serial port that does not cost much ..
  9. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
  10. alex92010
    Wow, thanks! then you can not buy already assembled? Thank you again for your support, I'll know.
  11. alex92010
    One other thing .. the pdf is not specified for the base building .. where I procured the base .. the pieces that I have already found all but the base does not know how to get, is already pierced correctly?
  12. alex92010
    Forgive me in the guide is a request for a 15 volt zener diode 250mW .. I do not find either to die .. you know where you could try? But is not the 3-foot is shaped like resistors.
