    Buy Download Package Now!
Chassis 2 DOF compact de Grand Strate
Discussion in 'French' started by Grand Strate, Mar 3, 2020.
  1. Grand Strate
    Grand Strate New Member Gold Contributor
    - 60Coins
    Bonjour.
    Je post quelques photos du châssis dynamique 2 Dof que j'ai créé.
    Sa particularité est que je l'ai imaginé compact pour pouvoir le ranger dans un coin de la pièce hors utilisation.
    La conception est en tube rectangulaire de 2 mm d'épaisseur.
    Certaine partie sont soudées, d'autres visser afin qu'il soit totalement démontable.
    Une fois ouvert pour jouer, des chaines se mettent en tension et il devient ultra rigide.
    Je tiens à remercier Simon de Simukit qui a été disponible a p u m'éclairé dans l'utilisation de Simtools.
    Google vTranslation:
    Hello.
    I post some photos of the dynamic 2 Dof chassis that I created.
    Its particularity is that I imagined it compact to be able to store it in a corner of the room when not in use.
    The design is in 2 mm thick rectangular tube.
    Some parts are welded, others screw so that it is completely removable.
    Once opened to play, chains are put in tension and it becomes ultra rigid.
    I would like to thank Simon de Simukit who was available to help me use Simtools.
  2. Ads Master
    Ads Master
    105,891Coins
    Thanks so much for sharing your foldable rig, it is awesome in terms of storage :thumbs
    Please be aware that you can dual language post but it is part of the Forum Rules that you also include an English translation: https://www.xsimulator.net/community/threads/forum-rules.9527/
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    I have taken the liberty of adding a Google Translation to your original post.
