Question Can you combine emergency off switch for DD with motion?
Discussion in 'Direct Drive Wheels' started by WedgeSD, May 2, 2022.
  1. WedgeSD
    WedgeSD New Member
    Design Engineer
    San Diego, California, United States
    163Coins
    DC motor, 4DOF
    I just picked up a Simucube 2 Pro, which includes, and requires an emergency stop being connected for the wheel to work. I already have an emergency stop on my rig for my motion rig. Would it be acceptable to wire both the DD wheel and motion to the same emergency stop? I am trying to keep my rig as clutter free as possible and if I can I would like to avoid bolting the second stop on. Has anyone done this?
    Thanks!
  2. Gadget999
    11,947Coins
    You should be able to daisy chain them together
  3. Thanos
    Electronics Engineer
    United States
    2,848Coins
    Many mushroom type e-stop switches have both NC and NO type connections (Normally Open, Normally Closed) on them that work in parallel.
    The AMC-AASD15A for example needs Normally Open e-stop wiring, and many DD drives need Normally Closed wiring. The two switch circuits are electrically separate, so each system can have different voltages for its wiring and will operate just fine with such dual function e-stop...
  4. WedgeSD
    WedgeSD New Member
    Design Engineer
    163Coins
    DC motor, 4DOF
    Once again, excellent information Thanos! This is super helpful insight. I will dig into the Simucube 2 and report back with my findings on the e-stop wiring status.
