Belt driven FFB wheel build help (Noob)
Discussion in 'DIY peripherals' started by Rauch, Feb 9, 2022.
  1. Rauch
    Rauch New Member
    18Coins
    Hi xsimulator community
    I am new to build FFB wheel so I need help.
    I have Dunkermotoren gr63x55 DC motor
    https://www.dunkermotoren.com/uploads/tx_products/downloads/MKS/gr-63x55-8844201157.pdf (datasheet)
    is this DC motor bad for build ?
    the torque is motor is low 0.27 if I multiple with gear ratio 10:1 is it okey ?
    and what powersupply do you recommend ? is 24V 20A okey ? (motor has 40v starting)
    motor have an encoder by itself 100 ppr ( maybe 10:1 gear ratio it will be 1000 ppr) (omron 1000 ppr ?)
    I will be use bts7960b and stm board
    thanks
