Question Basic PID setup JRK 12V12 & Motor Wipers
Discussion in 'New users start here - FAQ' started by JonBakhol, Dec 16, 2018.
  1. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    442Coins
    Hi Guys,
    After burning up a few MM boards, and an DBH-01 I decided to buy myself 2 JRK 12V12 boards.
    So I've got them laying on my desk. The setup should be easy...hmmmm
    I figured out almost everything but the PID calculation is the problem.
    I know @yobuddy post a nice piece of description for the JRK 12V12 boards. But still I'm afraid to blow these also.
    Is there is basic PID configuration for Wiper Motors where I can start from, and than figure it out myself a little bit more?
    Thanks in advance.
    145,052Coins
    +10,776 / 52 / -2
  3. hannibal
    hannibal Active Member
    4,489Coins
    wow.. so if using JRK boards,
    then arduino/raspberry are not needed?
    interesting that simtools sends data directly to the board!
    145,052Coins
    +10,776 / 52 / -2
    Correct, plus the JRKs have a great visual configuration tool, which makes setup a snap.
    There are now new JRKs, which SimTools supports, that are far more capable than the old 12V12s that were available when I built my rig.
  5. hannibal
    4,489Coins
    wow.. info is endless.
    i feel like i am a needle in a haystack.
    thanks @noorbeast
    please excuse my noob-ness.
    basically sabertooth/monster moto shield/L298N all do the same thing, which a motor controller boards, that are controller by arduino or rasberry pi?
    if arduino is used, does game data go follow this path?
    simtools -> arduino -> motor controller - motor / actuator
    if JRK is used, would it be,
    simtools -> JRK -> motor / actuators?
    i have soooo much to learn...
    by the way, so you actually straight up plug your motors on to the JRKs? if so how do power supplies tap in?
    145,052Coins
    +10,776 / 52 / -2
  7. hannibal
    4,489Coins
    thank you for replies and patience! <3
  8. wyoben
    wyoben New Member Gold Contributor
    USA
    86Coins
  9. hannibal
    4,489Coins
    coool! what question was that @wyoben ?
  10. wyoben
    USA
    86Coins
    @hannibal
    The one about interfacing differences. Arduino and JRK.
    So much to learn.
