Tutorial Based on SFX-100 improved DIY linear actuator
Discussion in 'Motor actuators and drivers' started by yondwangmms, Jun 21, 2020.
  1. yondwangmms
    yondwangmms Member
    - 148Coins
    Structural design introduction
    1,Design stroke: 100mm (customizable)
    2,Design speed: 200mm/s
    3,Main structural material: 80*80 aluminum profile 1205 Ball screw rod(All accessories are purchased from China Taobao)
    4,Motor options: 24v 350w DC permanent magnet brushed motor
    5,Single actuator rated load: 130kg
    6,Position feedback: 10k resistance conductive plastic linear displacement sensor(There are specifications for different itineraries)
    7,Motor driver: typical h-bridge driver or other equivalent driver
    8,arduino is equipped with smc, the software uses simtools
    154,460Coins
    +11,182 / 57 / -2
    Nice work :thumbs
    You will likely need to upload as a zip file.
  3. yondwangmms
    yondwangmms Member
    - 148Coins
    Thank you! This actuator may be the linear actuator with the highest bid ratio!
  4. Sim Freak
    Sim Freak Sim Freak Gold Contributor
    61Coins
    Hello! I'm interested to know more about your build. Can you post some photo or video of the end result?
  5. yondwangmms
    yondwangmms Member
    - 148Coins
    Can You Upload Your E-mail? The video can be e-mailed to you.
    154,460Coins
    +11,182 / 57 / -2
    Use the personal messaging system for exchanging personal information.
