Question axis only goes up to 100 , because it doesn't give me up to 180
Discussion in 'SimTools Pro & Entertainment Version' started by LUIS ALEXIS, Aug 31, 2022.
  1. LUIS ALEXIS
    LUIS ALEXIS New Member Gold Contributor
    - 181Coins
    2DOF, 3DOF, Arduino, Motion platform
    In the flight 2020 plugin in yaw it is 180 degrees but in axis simtool it is only up to 100. I have version 2.5.1 how do I make the plane 180 degrees without changing the direction of the axis
    150,686Coins
    +11,018 / 55 / -2
    The range for hardware is normally set with the control board and associated code.
    The SimTool range is a %, not degrees, so at 100 it will have the full range of motion the control hardware and code allows.
  3. Gadget999
    11,947Coins
    Do you mean you are only getting 100 degrees movement ?
    what type of actuator / potentiometer / control system do you use ?
  4. LUIS ALEXIS
    - 181Coins
    THE DOUBT OR THE PROBLEM I HAVE IS SIMTOOL BECAUSE IT ONLY GIVES ME UP TO 100 AXIS AND SHOULD GIVE 180 TO DELAY THE COURSE OF YAW AND THE MOVEMENT IS NOT REVERSED WHEN IT REACHES THE TOP, IN FSM2020 WHICH GIVES 360 DEGREES
  5. yobuddy
    50,333Coins
    Like Noorbeast said, Axis allocation is by percent, and 100% is the max for a percent input.
    Maybe if you post some screenshots we could help you more.
    Take care,
