Audrino Sketch to run Steppers
Discussion in 'SimTools compatible interfaces' started by Harry King, Dec 31, 2016.
  1. Harry King
    Harry King Member
    224Coins
    3DOF, Arduino
    Stepper Motor Control - speed control
    This program drives a unipolar or bipolar stepper motor.
    The motor is attached to digital pins 8 - 11 of the Arduino.
    A potentiometer is connected to analog input 0.
    The motor will rotate in a clockwise direction. The higher the potentiometer value,
    the faster the motor speed. Because setSpeed() sets the delay between steps,
    you may notice the motor is less responsive to changes in the sensor value at
    low speeds.
    Created 30 Nov. 2009
    Modified 28 Oct 2010
    by Tom Igoe
    #include <Stepper.h>
    const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
    // for your motor
    // initialize the stepper library on pins 8 through 11:
    Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
    int stepCount = 0; // number of steps the motor has taken
    void setup() {
    // nothing to do inside the setup
    void loop() {
    // read the sensor value:
    int sensorReading = analogRead(A0);
    // map it to a range from 0 to 100:
    int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
    // set the motor speed:
    if (motorSpeed > 0) {
    myStepper.setSpeed(motorSpeed);
    // step 1/100 of a revolution:
    myStepper.step(stepsPerRevolution / 100);
  2. csrealsimracer
    csrealsimracer New Member
    china
    316Coins
    a lot of work has to be done on this code
