Question Assetto Corsa Evo
Discussion in 'Assetto Corsa' started by Hermant Alexis, Feb 27, 2025.
  1. Hermant Alexis
    Hermant Alexis Member
    238Coins
    Hello
    Is there a new plugin in dev for AC Evo, or the previous one for ACC Competizione is compatible?
    Thank you ;)
    154,316Coins
    +11,179 / 57 / -2
    SimTools v3 has a plugin for both: https://simtools.us/plugin_library/
  3. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    I'm interested as well. Do you think a plugin for SimTools 2 will be released ? I'm stuck on this version because of my controller board isn't compatible with V3 :(
  4. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    Good morning
    For me it's the same thing
    A plugin for Simtools V2 would be great
    154,316Coins
    +11,179 / 57 / -2
    The information is available for anyone to write a SimTools 2 plugin: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
    The reality is that SimTools 2 is being superseded, and it is not just the time and skill it takes to write a plugin, it also has to be maintained. Someone would have to be willing to step up and invest their time and effort.
    I feel for you @Thierry59191, but if your rig worked with SimTools 2 then it could work for SimTools 3, which is a free upgrade, so that is a matter to do with the vendor, not SimTools. I appreciate it is an addition cost but swapping out the control hardware is one option to free the rig you already paid good money for, to transform it into something that is actually yours, that you control, not somebody else.
  6. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    Hello Noorbeast
    Thanks for your answer and I understand the problem.
    Is it possible to install simtools V3 and keep V2 also for old games in case V3 does not work well on my simulator?
    154,316Coins
    +11,179 / 57 / -2
    Yes, you can have SimTools v2 and v3 installed on the same computer, and use the same license key for both.
  8. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    This is good news and congratulations to the developers for thinking of it.
    I installed V3, no time to try it but in any case the interface is really beautiful
    see you soon
  9. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    last little question, I saw that old games had their plugins, is a plugin for NFS shift games possible? If yes, where to request it because unfortunately I would not be able to do it myself, my computer skills being more than limited
  10. pikky
    pikky New Member Gold Contributor
    24Coins
    So, can you use V2 in EVO? I'm stuck in V2 too.
    154,316Coins
    +11,179 / 57 / -2
    No, the comment has nothing to do with Evo, but rather the post is acknowledging the sensible dev approach that you can install both v2 and v3 on the same PC.
    As it so happens v3 supports Evo and the issue is figuring out whatever commercial shenanigans that prevents you upgrading. As an aside what pressure have you put on the commercial retailers to fix the issue?
