assetto corsa crash with simtools
Discussion in 'Assetto Corsa' started by gigi, Oct 20, 2018.
  1. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Good morning,
    I have this strange problem with assettocorsa and sim tools.
    I start first simtools and then assetto corsa. I choose the car and the circuit and I start but the loading stops and I have to turn off the PC to unlock. I then tried to start assettocorsa without simtools and it works perfectly. I also tried to start assertocorsa and start simtools after the beginning of a driving session. Also in this case it works. Incredible!
    I do not know if the thing is influential or not but the problem seems to be there after I installed a new pci sound card "creative sound blaster z" which I connected a sounbar with an optical cable. Previously the soundbar was connected to the sound card built into the motherboard and everything worked fine.
    Among other things, this problem is present only with assocorsa. With dirt rally everything works perfectly.
    Yesterday during the various attempts to unlock the crash appeared to me the message "acs.exe does not work"
    Today this message does not appear anymore. However following a suggestion found on racedepartment in assettocorsa \ system \ cfg | assettocorsa.ini I verified that this string was WARNINGS_AS_ERRORS = 1 to
    WARNINGS_AS_ERRORS = 0
    I have also uninstalled and reinstalled assetto corsa and I also uninstalled and reinstalled simtools but I have not fixed it
    What could be the problem?
    Thank you for the support
