Question AS5048 Magnetic Rotary Encoder instead of pots?
Discussion in 'Electronic and hardware generally' started by traveltrousers, May 17, 2017.
  1. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    153,053Coins
    +11,117 / 56 / -2
  3. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    I have played around using AS5040 and a magnet on end of shaft.
    They work well but for this application I would recommend using one that has analog output such as
    http://ams.com/eng/Products/Magnetic-Position-Sensors/Angle-Position-On-Axis/AS5043 or
    http://ams.com/eng/Products/Magnetic-Position-Sensors/Angle-Position-On-Axis/AS5263
    it would be a simple connection to the analog out to the controller.
    l think the biggest drawback is that it is a otp device, once a bit is prog to 1 there is no going back.
  4. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    Hello, I'm upgrading from wiper motors to a worm gear motor (120rpm). The seller was using it for robotics and has already installed a magnet on the motor along with an AS5040 and board. Is there any way to use this with the Arduino and Simtools using the digital output? or is analog the only acceptable input method for Arduino and Simtools? From your post, it sounds like getting the AS5043 or AS5263 is the only option? Sorry for the questions, i was excited because I thought I was getting exactly what I needed... but perhaps not...
