Arduino Sabertooth anyone?
Discussion in 'New users start here - FAQ' started by Gilby, Jul 21, 2014.
  1. Gilby
    Gilby New Member
    Auckland, New Zealand
    556Coins
    Hello Sim builders
    I have been looking at building my own motion for a long long time and have some of the hardware ready. (K8055+Satbertooth). T
    echnology moving very fast since. Does anyone here done Arduino+Satertooth with libraies from Dimension Engineering? Was it easy? Note I can't do any coding.
    Thx
    Gilby
  2. bsft
    @eaorobbie developed a plugin for k8055 and sabertooth. Not sure of where in the forum.
  3. eaorobbie
    20,465Coins
  4. Gilby
    Gilby New Member
    556Coins
    Thank you for the reply. It's about time to start my long over due project.
  5. RacingMat
    21,022Coins
  6. eaorobbie
    20,465Coins
    K8055 is running fine under SimTools, tested myself with big worms and a Sabertooth 2x12.
    @RacingMat do you need a hand, I can share the calc I used in my app for running a Sabertooth a couple of tricks I have learnt over the years.
  7. Gilby
    Gilby New Member
    556Coins
    Hi Mat
    I have been following your post and also found a French site having it setup with X-Sim. I can see the advantage to have digital signal over analogy plus better respond time for $20.
    This is going to be my 1st build. I think I will stick with K8055 and see what happen later.
    Thx both Mat and eaorabbie for the Simtool development.
  8. RacingMat
    21,022Coins
    Thanks @eaorobbie for your proposal! :thumbs
    I'll PM you as soon as I can work again on code.
