Tutorial arduino fan speed controlled by temp
Discussion in 'DIY peripherals' started by bruce stephen, Sep 24, 2015.
  1. bruce stephen
    general contractor
    michigan
    9,114Coins
  2. bruce stephen
    general contractor
    michigan
    9,114Coins
    ok ive compiled a parts list. now just wait for stuff in the mail.
    fan speed controller parts list
    1n4007 rectifier x 1
    bd139 transistor x 1
    100uf/16v capacitor x 1
    1k resistor x 2 v
    red led x 1 v
    16x2 lcd x 1 v
    lm35 temp sensor x 1 v
    photo resistor x 1 v
    12v fan 40mm x 2 v
    arduino x 1 v
    proto/bread board x 1 v
  3. bruce stephen
    general contractor
    michigan
    9,114Coins
    EDIT:THIS CODE DOES NOT COMPILE I HAVE POSTED A SIMPLER VERSION BELOW
    This is the code i intend to use.
    [​IMG] krowvin on March 10, 2015 at 3:48 am
    reply
    I modified your code to do a few things. I haven’t got to test it with the hardware yet (waiting on it to be delivered), but it seems to compile. Here’s my code if anyone would like to take a look.
    Added LDR (photo resistor to control LCD back light)
    Added a second fan (fans should function at the same speed)
    Add scenarios for when temp is below and above threshold
    (below fans turn off, above fans go to max)
    Also added code to show LCD as 0% or 100% Author has the line
    fanSpeed = 0; but I think he meant to use fanlcd = 0;
    #include <LiquidCrystal.h>
    //original: http://www.electroschematics.com/9540/arduino-fan-speed-controlled-temperature/
    LiquidCrystal lcd(7,6,5,4,3,2);
    int tempPin = A1; // the output pin of LM35
    int photoPin = A0; //photoresistor for LCD backlight
    int fan1 = 11; // the pin where fan is
    int fan2 = 10;
    int lcdbl = 9; // LCD backlight pin (connect to pin +15 on LCD
    // (NOTE: pin 16 is -)
    int led = 8; // led pin for HIGH temp warning
    int temp;
    int tempMin = 27; // 27C = 80.6F the temperature to start the fan
    int tempMax = 40; // 40C = 104F the maximum temperature when fan is at 100%
    int ldr = -1; //0..1023
    int fanSpeed;
    int fanLCD;
    void setup() { //set pins as input or outputs
    pinMode(fan1, OUTPUT);
    pinMode(fan2, OUTPUT);
    pinMode(led, OUTPUT);
    pinMode(lcdbl, OUTPUT);
    pinMode(tempPin, INPUT);
    lcd.begin(16,2);
    void loop() {
    temp = readTemp(); // get the temperature
    if(temp = tempMin) && (temp tempMax) { // if temp is higher than max temp
    digitalWrite(led, HIGH); // turn on led
    digitalWrite(fan1, HIGH); //set fans to max
    digitalWrite(fan2, HIGH);
    fanLCD = 100; //Shows 100% use on LCD for fan
    } else { // else turn off led
    digitalWrite(led, LOW);
    ldr=analogRead(photoPin);
    if(ldr<=511) { //if ldr is <= 511 turn backlight on
    digitalWrite(lcdbl, HIGH);
    } else {
    digitalWrite(lcdbl, LOW); //if greater, turn LCD BL off
    lcd.print("TEMP: ");
    lcd.print(temp); // display the temperature
    lcd.print("C ");
    lcd.setCursor(0,1); // move cursor to next line
    lcd.print("FANS: ");
    lcd.print(fanLCD); // display the fan speed
    lcd.print("%");
    delay(200); //give time to read text before changing
    lcd.clear();
    int readTemp() { // get the temperature and convert it to celsius
    temp = analogRead(tempPin);
    return temp * 0.48828125;
    +++++++++NEW CODE+++++++++++
    #include<LiquidCrystal.h>
    //source: http://www.electroschematics.com/9540/arduino-fan-speed-controlled-temperature/
    int tempPin = A1;// the output pin of LM35
    int fan =11;// the pin where fan is
    int led =8;// led pin
    int temp;
    int tempMin =30;// the temperature to start the fan
    int tempMax =70;// the maximum temperature when fan is at 100%
    int fanSpeed;
    int fanLCD;
    void setup(){
    pinMode(fan, OUTPUT);
    lcd.begin(16,2);
    void loop(){
    temp = readTemp();// get the temperature
    if(temp < tempMin){// if temp is lower than minimum temp
    fanSpeed =0;// fan is not spinning
    digitalWrite(fan, LOW);
    if((temp >= tempMin)&&(temp <= tempMax)){// if temperature is higher than minimum temp
    fanSpeed = map(temp, tempMin, tempMax,32,255);// the actual speed of fan
    fanLCD = map(temp, tempMin, tempMax,0,100);// speed of fan to display on LCD
    analogWrite(fan, fanSpeed);// spin the fan at the fanSpeed speed
    if(temp > tempMax){// if temp is higher than tempMax
    digitalWrite(led, HIGH);// turn on led
    }else{// else turn of led
    lcd.print(temp);// display the temperature
    lcd.print("C ");
    lcd.setCursor(0,1);// move cursor to next line
    lcd.print(fanLCD);// display the fan speed
    lcd.print("%");
    delay(200);
    lcd.clear();
    int readTemp(){// get the temperature and convert it to celsius
    return temp *0.48828125;
  4. jaco73
    jaco73
    interesting !! Thank you
  5. tombo
    tombo Active Member
    2,442Coins
    DC motor, Arduino
    Looks interesting. Thanks for sharing, maybe I can include this in my Diy Led Lamp.
