Arduino code to drive 4 motors
Discussion in 'SimTools compatible interfaces' started by Nicko355, May 2, 2015.
  1. Nicko355
    Nicko355 New Member
    Automotive Tech
    Sydney , Australia
    483Coins
    Hi, ok so I have learned more from experimenting with Racingmats build instructions, so far i am beginning to understand the relationship between AXIS and DOF , i am using racingmats 2Dof arduino code , my question is can i run 4 motors with this code? Or does it need to be modified?
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Although I don't know that much about coding ... But obviously what is written for a 2DOF can't be used for 4motors without modifications ... [ Motor Drivers ] need specific signal requirements to operate properly ... some of them operate with two direction signals and the others just operate on one direction signal for forward and reverse operation .
  3. Pit
    30,510Coins
    As far as I know Ard supports up to 3 motors - depending on the code.
  4. speedy
    Alexandria , Egypt
    7,948Coins
    Yes @Pit ... and I guess @prilad and his colleagues did it for 6 motors on the mal4x.ru forum ... but I don't know why ? I still can't read it under Google translation .
  5. RacingMat
    21,082Coins
  6. Nicko355
    Nicko355 New Member
    Automotive Tech
    Sydney , Australia
    483Coins
    Ok yes Racingmat, I just re read your code and I understand it better , so i will connect another motor monster and 2 more motors and continue experimenting, THANKS ALL once again CHEERS Nick
  7. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    And what if we want to use four bigger motors (250w) and we have to use two MM for each?
  8. RacingMat
    21,082Coins
    @gorzasty
    4 motors driven by 8 motomonster only require 1 arduino and same code :)
    because 2 motomonsters wired together is seen like a single motomonster : 1 PWM pin and 2 Direction pins
  9. gorzasty
    Poland, Wrocław
    1,060Coins
    Sorry my mistake @RacingMat, I was thinking about the 4 mototrs driven by the 4 MM. Thx to @Pit thread I know that we can use wireings like this:
    Arduino -------- Monster Moto
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 3
    6 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    7 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    11 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    but no word about 4'th motor. I think there is no place for it in the Arduino, but I'm a newbe...
  10. RacingMat
    21,082Coins
  11. gorzasty
    Poland, Wrocław
    1,060Coins
  12. kingh3
    kingh3 Member
    256Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Motion platform
    Excuse me! could you tell me about the data from simtool sent to arduino? A packet of data include 8 bit or 3 bit? And I don't understand how it calculate in this episode:
    byte Data[3]={'0','0','0'};
    // keep this function short, because the loop has to be short to keep the control over the motors
    if (Serial.available()>2)
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L')
    Data[1]=Serial.read();
    Data[2]=Serial.read();
    // call the function that converts the hexa in decimal and that maps the range
    DataValueR=NormalizeData(Data);
    Could you explain to me? Thank you so much. @RacingMat
  13. RacingMat
    21,082Coins
    why do you want to change anything?
  14. kingh3
    kingh3 Member
    256Coins
    No, I don't want to change. I just don't understand about it.
  15. fafay
    fafay New Member
    boulanger patissier
    france albi
    341Coins
    It's not all bad
    I will try when I receive my two card monster motorcycle
