Anybody familiar with this servomotor?
Discussion in 'Motor actuators and drivers' started by superwhitewish, Mar 22, 2020.
  1. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    While browsing in Aliexpress, I found this integrated drive servomotor that are quite low price.
    https://www.aliexpress.com/item/329...earchweb0_0,searchweb201602_,searchweb201603_
    Voltage is 36v dc
    Power is 180w
    Rated speed is 3000rpm
    Rated torque is 0.6nm
    I did some calculation at https://www.fxsolver.com/browse/formulas/Ball+Screw+-+Driving+Torque
    The motor paired with 5mm lead ball screw could lift around 50-60 kg of load. Combined 4 motors like the Dbox layout could lift around 200 - 240 kg of load if well balanced.
    So I write an Arduino code to see if I can run 4 of these motor on a single Uno. The code will regulate the speed of each servo while tracking the position and output pulses to the controller. I still dont have the PID routine but I just simulate the PID process with 250 microseconds delay. PID process is called every 500microseconds (2000 per sec).
    Code:
    #define MAX_SPEED 24000               // target is 150mm/s = 30rev/s(5mm lead) = 24000pulse/sec (based on servomotor with 800ppr)
    #define PID_PERIOD_uS 500
    int motorPulsePin[4];
    int motorDirectionPin[4];
    unsigned int motorPosition[4] = {0};  // target is 100mm travel = 20rev x 5mm screw lead
                                          // pulses = 20rev x 800ppr = 16000 pulses for 100mm travel.
    int motorSpeed[4] = {0};              // pulses per second
    int motorDirection[4] = {1,1,1,1};    // values are 1 or -1
    int motorAcceleration[4] = {0};       // pulse/s^2
    int motorPulse[4] = {1,1,1,1};        // 1 or 0
    unsigned long motorHalfPulseTime[4] = {0};
    unsigned long motorTimesUp[4];
    unsigned long PIDTimesUp;
    unsigned int pps[4] = {0};   //to calculate
    unsigned long ppsTimer = 0;  //actual pulse per sec
    void setup() {
      Serial.begin(115200);
      // wait until serial port opens for native USB devices
      while (! Serial)delay(1);
    void PIDRun(){
      if(micros() - PIDTimesUp < PID_PERIOD_uS)
        return;
      PIDTimesUp += PID_PERIOD_uS;
      //simulate time for PID calculation
      delayMicroseconds(250);
    void motorRun(int i){
      if(motorSpeed[i] <= 0)
        return;
      motorHalfPulseTime[i] = 500000 / motorSpeed[i]; //time in microsec.
      if(micros() - motorTimesUp[i] < motorHalfPulseTime[i])
        return;
      motorTimesUp[i] += motorHalfPulseTime[i];
      if(motorSpeed[i] > MAX_SPEED)
        motorSpeed[i] = MAX_SPEED;
      //send pulse to controller
      //digitalWrite(motorDirectionPin[i], motorDirection < 0 ? 0:1);//motorDirection is 1 or -1
      //digitalWrite(motorPulsePin[i], motorPulse);
      motorPulse[i] = 1 - motorPulse[i]; //toggle pulse signal
      //update motor position every time pulse is logic 1
      if(motorPulse[i]){
        motorPosition[i] += motorDirection[i];
        //calculate actual pulse per sec
        pps[i]++;
    void loop() {
      for(int i = 0; i < 4; i++)
        motorTimesUp[i] = micros();
      PIDTimesUp = micros();
      ppsTimer = millis();
      motorSpeed[0] = 2000;
      motorSpeed[1] = 2000;
      motorSpeed[2] = 2000;
      motorSpeed[3] = 2000;
      while(1){
        PIDRun();
        for(int i = 0; i<4; i++)
          motorRun(i);
        //print pulse per sec every 5 secs
        if(millis() - ppsTimer > 5000){
          for(int i = 0; i < 4; i ++){
            Serial.print(i+1);
            Serial.print(" Speed : ");
            Serial.print(motorSpeed[i]);
            Serial.print("   ");
            Serial.print("PPS Created : ");
            Serial.print(pps[i]/5);
            Serial.print("   ");
            Serial.print("Pos(5secs): ");
            Serial.println(motorPosition[i]);
            pps[i] = 0;
          Serial.println();
    The code manage to give a maximum of about 1200 pulse per sec for each motor. But looking at the motor manual, the lowest PPR setting via dip switches is 800PPR. If I aim for 100mm/s actuator movement, that would need around 16000 pulse per second.
    However I found out that there is a setting in the manual that you can adjust for 'electronic gear ratio'.
    Here is the manual
    https://www.cnc-technics.de/ihsv servomotor.pdf
    What I understand from the manual is that, by adjusting the ratio, I can set how many pulse needed for a revolution . If I set the ratio to 13, I can move the actuator at 100mm/s with just 1200 pulses per sec. But I am not entirely sure and I don't want waste money buying things that I cannot use.
    Anyone here familiar with these motors? Am I correct about the 'electronic gear ratio'? Do you think it is doable with just Arduino Uno..?
