Angles
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by drzmat, May 13, 2020.
  1. drzmat
    drzmat Member
    184Coins
    Hi, i am planning my motors position on my 2dof setup and i would need someone to explain me the difference between the "rest angle" and "current angle" in simcalc.
    Thanks a lot!
    154,238Coins
    +11,176 / 57 / -2
    Just some context - The most effective use of torque is when the angle of force is at 90 degrees to what is being acted on. For example if you push on an open door with your little finger, at 90 degrees, you can easily move the door. The more acute the angle the harder it is to effectively push the door.
    So, if you have a compact rig the levers at rest would be 0 degrees, as that means the rods are 90 degrees to them, directly connected to the base of the seat.
    But if you have a shoulder mount rig, with the motors behind the seat, for the lever to rod angle to be at 90 degrees the levers at rest will likely be at say 40-45 degrees, depending on how far back the motors are from the seat and how high the connecting mount is.
    To summarise the at rest angle for the levers is to position them at 90 degrees to the rods, which in turn are connect to and move the seat, with design affecting what the rest angle will be.
  3. drzmat
    drzmat Member
    184Coins
    Thanks for this Noorbeast, but what about that "current angle"?
    What is it?
    I understand the "rest angle" now, no problem there.
    154,238Coins
    +11,176 / 57 / -2
    It is the current angle of your CTC lever, measured in degrees away from the zero position.
  5. drzmat
    drzmat Member
    184Coins
    Yeah thats the part i dont understand....
    Sounds the same as the rest angle to me...
    Lets say i have a rear shoulder mount setup with motors at the rear, my ctc rest angle should be around 45 degrees from the ground, rods at 90 degrees from lever, now what about that current angle? if my setup is currently leveled it will be 45 as well?
    I just dont understand the role of this value (current angle) in simcalc
    Sorry for my misunderstanding!
    154,238Coins
    +11,176 / 57 / -2
    You can use the current angle to check resultant forces across the intended range of the lever.
  7. drzmat
    drzmat Member
    184Coins
    Ha there you go!
    Thanks noorbeast!
