Question AIUTO!!!
Discussion in 'SimTools compatible interfaces' started by andrea necchi, Sep 14, 2019.
  1. andrea necchi
    andrea necchi New Member
    60Coins
    CIAO A TUTTI, HO UN PROBLEMA DI CONFLITTO TRA SIMTOOLS ED IL MIO G29 LOGITECH
    PREMETTO CHE SEPARATAMENTE FUNZIONANO ALLA PERFEZIONE MA, CON SIMTOOLS ACCESO APPENA COLLEGO IL VOLANTE ALLA USB VA TUTTO IN CRASH, SIMTOOLS SI CHIUDE E IL MIO 2DOF NON RISPONDE PIU... SONO DISPERATO, HO GIA FORMATTATO IL PC CREDENDO FOSSE UN CONFLITTO TRA DRIVERS MA NULLA.. STESSO DIFETTO!! NON SO DOVE ANDARE A PARARE.
    Moderator Edit:
    HI TO EVERYBODY, I HAVE A CONFLICT PROBLEM BETWEEN SIMTOOLS AND MY G29 LOGITECH PREDICT THAT SEPARATELY WORK AT PERFECTION BUT, WITH SIMTOOLS ONLY JUST CONNECTED THE WHEEL TO THE USB GOES ALL IN CRASH, SIMTOOLS CLOSES AND MY 2DOF DOES NOT RESPOND . I HAVE DISPERSED, I HAVE FORMATTED THE PC BELIEVING IT WAS A CONFLICT BETWEEN DRIVERS BUT NOTHING .. THE SAME DEFECT !! I DO NOT KNOW WHERE TO GO.
    154,526Coins
    +11,185 / 57 / -2
  3. yobuddy
    51,669Coins
    Are you using a USB hub?
  4. andrea necchi
    60Coins
    No
  5. yobuddy
    51,669Coins
    What all do you have plugged into usb?
    Maybe they pull to much power or something?
  6. andrea necchi
    60Coins
    steering wheel, simulator, mouse and rgb keyboard
  7. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    The power supply may be connecting the negative cable of the pedal potentiometers to the ground using the cockpit. You can try to separate the pedals of the cockpit to see if that is it.
  8. andrea necchi
    60Coins
    ora provo con 2 PC collegati via Ethernet con cavo crossover
