Question Actuator info needed
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Les Call, Feb 24, 2020.
  1. Les Call
    Les Call rotax 912 Gold Contributor
    retired
    81Coins
    Hi .
    Am looking to use a actuator for the Yaw for 3 DOF to be fitted under my rig anybody give me some info about what type to use and also specs if possible so that it can be run from a MM using 12 volt dc, supplier would also be good.
    Les.
  2. Zed
    USA
    5,842Coins
    There’s a number of 12V motors people use here. The pgsaw-style motors are 12V and they have been used on rigs for yaw/traction loss depending on where the pivot is located and people frequently use MMs to control those. Some have used wiper motors if I recall correctly. Just need to make sure internal grounds are cut.
