Access position data (feedback)??
Discussion in 'Forum and Website' started by KWhale, Oct 14, 2019.
  1. KWhale
    KWhale New Member
    183Coins
    Obviously rotational position data is passed straight through from the game to Simtools, where it is scaled and then straight on to the simulator. So the that data is available to the game, discounting delays, presuming a fully functional sim, if I'm understanding things correctly.
    But I would like to access raw/real-world position data of the simulator. Is there anyway to access that (presumably two-way data transmission via UDP via the game plugin) short of direct measurement?
  2. dododge
    dododge Active Member Gold Contributor
    854Coins
    A situation where this regularly comes up is when trying to remove rig motion from the view in a VR headset, so that you only feel the motion without seeing the view shift around.
    I think the only consistent/reliable approach so far has been to attach a tracking device to the rig and use an external tracking system -- typically whatever system is already in place to track the VR headset.
    While in theory you could use the actuator/motor feedback sensors to figure out the actual position, every rig design would require custom computations/parameters. That said, I think some people have looked into that approach. You can probably find more in the VR forum.
  3. WalkerYYJ
    WalkerYYJ Member
    197Coins
    You would need to implement forward kinematics to get live position though wouldn't you? My understanding with the inverse kinematics equations (I think thats what everyone uses... Right???) is that although the platform may know where it is at point A, or at point B... When its translating from A to B the actual platform location is "fuzzy".
    That being said if I'm misunderstanding it all please let me know!
    150,572Coins
    +11,017 / 55 / -2
    See here regarding the existing SteamVR approach to motion cancellation and discussions about other possible approaches, such as inverse kinematic and rig tracking: https://www.xsimulator.net/community/threads/vr-motion-cancellation-time-to-test.10241/
    The camera based tracking attached to the rig suffers from drift and both that and Lighthouse based tracking have issues with powerful transducers. Accurately tracking a rig and inverse kinematics both have significant challenges.
