6DOF Project, design considerations
Discussion in 'DIY Motion Simulator Projects' started by Aerosmith, Jul 29, 2024.
  1. Aerosmith
    Aerosmith Active Member
    self employed
    2,549Coins
    3DOF, AC motor
    Ok, I think I have found an acceptable layout.:thumbs
    The projection areas overlap a bit which leaves some reserve for adjustments. The light beams do not interfere with the pilot's head or the dashboard. I even have some headroom to the ceiling when the actuators are fully extended.
    However, this excludes the installation of an overhead panel. It would have to be mounted above the projector level and would be out of (comfortable) reach. Manipulating switches on it would throw shadows. Bad luck but no desaster. You can't have everything.
    Good question. There is no technical data available. I had to measure it. The amp meter of my workbench supply shows 0.5A at 220V. That's 110W. So a total of 440W should be manageable if I add some ventilation.
  2. Aerosmith
    self employed
    2,549Coins
    3DOF, AC motor
    A really cool thing are LED screen panels that can be combined like tiles. Bendable/curved types are also available. You can build a wall or even a complete room out of them . Check out this!:o::cool:
    However, the high quality types are prohibitively expensive. There are cheap ones on AliExpress but most of them have a pixel pitch of >1mm so they are only suitable for advertisment walls.
  3. GettinBetter
    GettinBetter Magna Merchant Gold Contributor
    CAD Engineer
    Kent, UK
    483Coins
    Yes, I saw those some time ago whilst exploring my options, I then realised that I can't afford what I really want. Much like a real helicopter
  4. Aerosmith
    self employed
    2,549Coins
    3DOF, AC motor
    Unfortunatelly, I have been very busy almost all the time since the Xmas holiday. There was almost no progress with my project. At least, the actuators were finished ... errr, almost. I mean 11 out of 12 so we could finish Sven's rig. But one of the actuators still has problems with the ball screw. One of the ball nuts seized inside the bushing. I had to heat it to get it disassembled but this damaged the wiper rubbers and the balls spilled on the floor.:eek::oops:
    I had no patience to repair it so I ordered two new screws and 3 bushings.
    They have arrived today so I no longer have any excuses.:D
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    Indeed, you have no excuse.
