Showroom 6DOF Build (Bodine Motors, Sabertooth, FlyPT Mover)
Discussion in 'DIY Motion Simulator Projects' started by BondeX, Mar 10, 2016.
  1. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Updated: Hey guys, so I will be starting my 6 DOF build using 42A3BEPM-E3 motors.
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,015Coins
    Look at this motor (350w 60rpm 45Nm).
    You can ask for a special shaft. I ordered with dual shaft, this is very useful and very good quality !
  3. Wanegain
    Bruxelles
    2,015Coins
    @BondeX look at the datasheet :
    12V 300W : 40Nm
    12V 500W : 50Nm
  4. Wanegain
    Bruxelles
    2,015Coins
    12V 180W= 50-60Nm is impossible. This is most probably the brake torque, so it means half torque ;)
    I have 24V 120W 25Nm too and it's true.
  5. Wanegain
    Bruxelles
    2,015Coins
    Yes but they are very expensive :confused:
  6. Historiker
    Michigan USA
    9,214Coins
    Yes, 1370.00 USD...for that kind of money I would go with AC to be honest.
  7. Historiker
    Michigan USA
    9,214Coins
    Even at 700.00 each I would still go with AC. That is a very high price for 12v motors....
  8. Historiker
    Michigan USA
    9,214Coins
    OH!!! Now that makes sense :)
  9. Historiker
    Michigan USA
    9,214Coins
    Sorry, I cannot give you advice for this purchase. I built my 6DoF with winch motors. I do look forward to seeing what you come up with.
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    it all seems so expensive still though. I picked up 9 motors for less than $500. I would think there is some less expensive route. I would think less than 100bucks each is out there.
  11. Historiker
    Michigan USA
    9,214Coins
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
  13. Historiker
    Michigan USA
    9,214Coins
  14. Wanegain
    Bruxelles
    2,015Coins
    These motors are good (120W 40rpm 25Nm). You need to use them on only 120° to get a good speed.
  15. noorbeast
    153,137Coins
    +11,117 / 56 / -2
    A purchase is always your own decision. But if it were me at twice the cost I would stick with pgsaw, based on known real world use and the positive feeddback from members like @shannonb1 and @Nick Moxley who actually use them.
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    after a brief search Ive concluded its "slim pickins" right now. pgsaw may be your guys.
  17. BondeX
    EE
    Michigan, USA
    1,501Coins
    Alright motors aside. Here is what I will be ordering and the links where I will be ordering them from. Please let me know if I should make any changes. Thanks
    12 Ball Joints M12-1.75 ($45.60): http://www.aliexpress.com/item/4pcs...ight-hand-tie-rod-end-bearing/1559309095.html
    Threaded rods to go with the ball joints. Should be plenty strong for silent chill type 6DOF
    6 M12-1.75 x 1meter Threaded Rods ($62) :
    Which MMs to pick, ebay could get me my money back if they are bad. I think.
    12 MMs ebay ($92): http://www.ebay.com/itm/Dual-VNH2SP...124107?hash=item3d0105374b:g:UooAAOSwd0BV0wBq
    or
    12 MMs Ali Express ($75): http://www.aliexpress.com/item/Free..._3&btsid=24dfad66-a103-495d-8d45-5e407a94002b
    4 Arduino UNOs ($21.91) :
    http://www.ebay.com/itm/NEW-ATmega3...623468?hash=item3aa96d6aec:g:1EMAAOSwuMFUdtk9
    6 Hall Effect Pots ($82) : http://www.mouser.com/Search/Produc...rtualkey57700000virtualkey858-6127V1A360L.5FS
    Not sure what kind of shaft coupler to get for mounting Pots, which should depend on the type of motor (Either Bodine or PGSAW)
    6 Shaft Couplers ($33) :
    http://www.aliexpress.com/item/6Pcs..._3&btsid=50187861-79fc-42e9-8459-f4d456f0ba91
  18. noorbeast
    153,137Coins
    +11,117 / 56 / -2
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
  20. SilentChill
    20,598Coins
    Go with the pgsaw I would if it was me not too bad of a price, I was lucky to get my motors for free ;)
    The MM's are hit and miss with the clones/copies you will get some faulty as they all come from china, so I would order a few more than you need.
    I would also go with the 180 degree pots if I was to buy again no need for 360
    • Agree Agree x 3
