60st m01330 servor 2DOF
Discussion in 'New users start here - FAQ' started by Ilyesgtsport, Apr 13, 2023.
Tags:
  1. Ilyesgtsport
    Ilyesgtsport New Member
    - 299Coins
    2DOF, 3DOF, Arduino
    Hello I'm new here, I followed a lot of projects, and I started my 1st 3 dof TL with wheelchai motor A month ago but unfortunately I couldn't finish it for lack of parts and especially because the BT2 heats up a lot in test mode, so I turned to the Plan B with SERVO Motor and I saw a lot of projects, it's more expensive but more efficient and efficient and no motor driver overheating. So this time I bought the Simtools Pro license to train on the TOOLS and learn how to use it and I did a research on the availability of parts to build the Actuator . I found everything except for the Motor I did not find the 90ST but I found his little brother the 60st m01330 and since my simulator will be 2DOF I think it can do the trick and really I have seen a lot help here by the community and especially the experienced Member who encourage The beginners. So I would like help and support to Make MY 2DOF. MY 1st Question: Can I use the same component as the famous SFX!! With rod 1605?
    SEcond Question : The ARduino code work with this 60ST Motor same or i must make Modification And CHange .
    Best Regards
  2. Ilyesgtsport
    - 299Coins
    2DOF, 3DOF, Arduino
    some help or suggestion
    150,686Coins
    +11,018 / 55 / -2
  4. Ilyesgtsport
    - 299Coins
    2DOF, 3DOF, Arduino
    The Problem in my country we can't import from international , just big company are allowed to make transaction international , so i haven't choice , i'm looking for those motor 6Ost cause i found it here , so i must make the sim with arduino
  5. Thanos
    Electronics Engineer
    United States
    2,848Coins
    If the 60st m01330 servomotor comes with AASD-15A servo drive and all wiring (KIT), yes, you should be able to use them with AMC-AASD15A controller.
    Just make sure you are getting servo drive as well, not just a motor.
