600w / 900w 12v Gear Motor
Discussion in 'Motor actuators and drivers' started by CLEOPHUS, May 9, 2016.
  1. CLEOPHUS
    CLEOPHUS Member
    229Coins
    First Post. I have been trolling the forums for a bit, and haven't seen anything on these particular motors, so I would like to see what everyone thinks about them. I am planning a smaller scale 6dof, and really want to go the DC route due to lack of a 220v line in the area where it will reside. I started to look locally for used gear motors and stumbled across these new Dump Truck Tarp Motors from a place a mile away from where I live in Ohio.
    (Cant post links because its my first post, also there are several cheaper places to buy on the new - but Amazon had best specs)
    600w (0.8HP) version:
    90:1 gear for approx 40 RPM
    Search Amazon: Buyers Products 5541095 Tarp Gear Motor
    900w (1.2HP) version:
    60:1 gear for approx 60 RPM
    Search Amazon: Buyers Products 5543965 Tarp Gear Motor
    The specs tell me they would be a perfect fit - but I would like everyone's opinion.
    Thanks in advance.
  2. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Those are some big motors. Even on Amazon the prices are pretty good for a motor with that much power. Of course it matters how much stuff you stack on top of your 6DOF platform and your range of motion. But for most typical setups a 600W or 900W motor would be plenty big enough. Either motor should have plenty of power, so I would lean toward the higher speed one.
    What motor driver are you planning on using? Peak current could top 100A for each motor, so this would take a serious motor driver. Also I assume you are planning to run off car batteries? It would take some big power supplies and multiple 20A circuits (at least 3) to power a 6DOF with these directly.
  3. CLEOPHUS
    CLEOPHUS Member
    229Coins
    Wow. I guess I haven't thought the peak amps or the watts to amps calculation. I only have 2 - 20a circuits available at the location. I planned on using Moto Monsters or the AMC1280USB. The 30 amp limit of the motos wont cut it. I don't think these are going to work! Thank you for the reply.
  4. BlazinH
    16,651Coins
    I've used those motors before myself. They have a large brass gear that's only 1/8" or so wide. With the power they have it doesn't take much to start breaking off teeth.
  5. cgodwin
    Engineer
    Eugene, Oregon
    2,478Coins
    If you don't need full power, you can limit the duty cycle of the motors any maybe keep it down to what a Moto Monster can handle. I'm not sure if the 30A limit is instantaneous peak (less than a millisecond) or average over some length of time. 30A x 12V = 360W. Six of those, and assuming 90% power supply efficiency comes out to 2400W, or exactly what a single 20A 120V outlet can handle. Since you shouldn't ever have a situation where all 6 motors are at maximum at the same time (except maybe a big heave event?) that should give you some safety margin.
  6. Rocco
    Rocco New Member
    Phoenix, AZ
    83Coins
    Wow, that's a tiny gear for a ~1HP motor. Any pics of the internals by chance?
  7. CLEOPHUS
    CLEOPHUS Member
    229Coins
    I would love to see the internals too.
  8. BlazinH
    16,651Coins
    If I can find the time, I'll open one up again to show you. I put the covers back on them because they are filled with oil which is what makes the gearboxes so large. But, since the diameter of the worm gear is quite small, it goes to figure that their is not much contact area between the worm gear and the spur gear. Therefore, there is no purpose in making the spur gear much wider than the contact area of the worm gear.
  9. Rocco
    Rocco New Member
    Phoenix, AZ
    83Coins
    I see that the popular gear motors from pgsaw on eBay are rated at 180w vs 600w/900w for these tarp gear motors. Are these tarp gear motors truly that much more powerful than the pgsaw eBay motors, or is it some marketing trick where the motors are rated unloaded vs loaded or something?
    Just trying to determine which motor to go with between the two...
  10. Nick Moxley
    17,056Coins
    I would venture to say the 600/900w is a little inflated for marketing purposes. ;)
  11. Rocco
    Rocco New Member
    Phoenix, AZ
    83Coins
    Yeah, figured. :) You are running the pgsaw 25:1 motors, right? At any point have you wanted something more powerful or faster? I'm planning on a "desk racer" design, not a shoulder mount, so was thinking the more power, the better.
  12. Nick Moxley
    17,056Coins
    Yes im running 25's and You'll want 50's for your setup.
  13. BlazinH
    16,651Coins
    Its true that motors wattage ratings are often stated incorrectly due to standards not being applied, especially when its a Chinese import.
    The best way to judge a Chinese motor though is by its size since they mostly all use the same magnet type. For example, a motor referred to as an 80zyt means is casing is 80mm in diameter. If the casing is 100mm in length (not including the front and back covers) then its a 600watt motor. For every 25mm more in length, add another 200watts. This should hold true for any Chinese motor with an 80mm diameter casing.
    The Buyers Products motors I have are 80mm by 125mm long casing. They were claimed to be 1.2HP. But 125mm would make them only 800watts by my estimation.
    For US motors, like Bodine, you can't make the same estimation though because the US doesn't have low cost, high power magnets readily available like China does. Therefore they usually use less powerful magnets in comparison making US motors larger watt for watt. This in turn leads to more raw materials being used watt for watt also. While this adds more to their cost, there is the side benefit they they will dissipate heat faster due to their larger mass which is some consolation.
    • Informative Informative x 3
