Showroom 5 DOF Motion Rig With TL On A Simetik K2 Cockpit
Discussion in 'DIY Motion Simulator Projects' started by DotComRich, Mar 7, 2019.
  1. Cyberbug
    Cyberbug New Member
    29Coins
    SCN6, Motion platform, 6DOF
    Excellent build, interested to see the next upgrades
  2. Gregkar
    Gregkar New Member
    24Coins
    @DotComRich Excelllent work! i also have a Simetik K2, i was thinking going SFX-100, any chance you can send me a PM with all the parts and dimensions you got so you could add the actuators to the chassis? Please? it is pretty much the only thing that keeps me from adding motion
  3. DotComRich
    DotComRich Member
    531Coins
    2x https://us.misumi-ec.com/vona2/detail/110302690310/?HissuCode=HFSB8-4080-635
    4x https://us.misumi-ec.com/vona2/detail/110302690310/?HissuCode=HFSB8-4080-200
    16x https://us.misumi-ec.com/vona2/detail/110300449520/?HissuCode=HBLFSNF8-SST
    Then some nuts and 4x long bolts to go through the front of the frame and some short ones for the back. Can't remember the exact length I used. You can opt for more brackets as well if you want to put some on the inside of the cockpit for maximum sturdiness but I don't think its needed, maybe at the back where it's thin could help but I honestly don't notice any issues.
  4. Gregkar
    Gregkar New Member
    24Coins
    Thank you so much! do you remember the alu profile lengths or the values are correct in the links you sent (635mm and 200mm)?
  5. DotComRich
    DotComRich Member
    531Coins
    Those are the exact lengths I ordered
  6. DotComRich
    DotComRich Member
    531Coins
    Ok the wood is finally starting to give, its time to start planning my next TL platform. I want to make a simple T shaped base for it to slide on but I am having a tough time finding a material to use that I can get custom cut that will be strong enough, any recommendations?
    I need it to be roughly 1300mm length, 200mm width
    Was looking to go with something like this but it wouldn't ship until the end of Aug, I can't wait that long lol.
    https://us.misumi-ec.com/vona2/detail/221005478100/?ProductCode=AFR-25170-6-1200
  7. DotComRich
    DotComRich Member
    531Coins
    Been working on a new custom aluminum extrusion TL platform, here she is. Rolls smooth as butter and is surprisingly quiet. This setup is going to give me nearly double the amount of movement over my wooden platform, can’t wait! Will post more details on it later.
    42309C61-F21C-41A9-B60C-4F3E0468D0CB.jpeg 2C3F006C-8E11-430D-AEB0-B7061408F786.jpeg 4BA18C8B-424E-4811-8E5C-71C0866FBB2B.jpeg A462ECB9-79FC-4967-B18F-3F4012E655A0.jpeg
    • Like Like x 5
  8. DotComRich
    DotComRich Member
    531Coins
    All done! Feels much smoother and more rigid than my old wood platform. Also has a much smaller footprint, 6” lower and fits nicely in this corner.
    Also got all the electronics, servo drivers, pc etc behind the wall to keep things cleaner.
