Showroom 4040 aluminium profile with 2dof seat mover
Discussion in 'DIY Motion Simulator Projects' started by Meawto, Jan 9, 2017.
  1. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    hello this is my project for seatmover with aluminium profile. for less space room and non welding rig
    (download may-cad file here https://drive.google.com/open?id=0B2uC4zudtNqXTWFkVWFOQTFNNk0)
    my system use arduino uno with ibt-2 h-bridge and 2 hall effect pots
    with SMC3 firmware
    14656241_1188104394597662_2787100064107270685_n.jpg 15326034_1250340145040753_7385776273434746398_o.jpg 15326296_1250340108374090_9045786760266183897_o.jpg
    aluminium profile arrived !! :D
    15319146_1245145238893577_3527458052206974969_n.jpg 15241268_1245914795483288_8846895922034231191_n.jpg
    x2 worm gear motor from motion dynamic australia
    15272225_1246412905433477_6980491968539660752_o.jpg 15304407_1246412908766810_1840657772572909018_o.jpg
    this is my motors shaft
    need to swap those shaft side !!
    15241287_1248072511934183_7218611572626754473_n.jpg 15326531_1248100688598032_8699547624193200004_n.jpg
    Meow !! brb
  2. Meawto
    Thailand
    - 336Coins
    ok this is how i mount the sensor and motor arms
    14938031_10205870210154762_1994349972_n.jpg 14962935_1214304245311010_1102047015_n.jpg 15320410_1254162201325214_1342233280_n.jpg 15356916_10206104830420122_1462838657_n.jpg 14962242_1214302521977849_1474910792_n.jpg
    recaro is comming :cheers
    15171262_1243526519055449_5870584315335244491_n.jpg 15202564_1243526495722118_6320708594922209412_n.jpg
  3. Meawto
    Thailand
    - 336Coins
    let's make the cockpit !!
    15252512_1246264428781658_2258114248916664419_o.jpg 15271920_1246264318781669_4915157151856745302_o.jpg 15271922_1248935888514512_9087444470501406493_o.jpg
    15325297_1250340058374095_728475698058466500_o.jpg 15271792_1250340045040763_3582365720224842367_o.jpg 15355592_1250340191707415_6798819486763107991_n.jpg
    15369773_1254162254658542_1439509273_o.jpg 15369072_1252558461485588_8711178223865715999_o.jpg 15250884_1249926111748823_4344351221837600467_o.jpg
    Pid test
  4. Meawto
    Thailand
    - 336Coins
    first test
  5. Meawto
    Thailand
    - 336Coins
    now i have change heatsink of ibt-2 for more performance
    keep everything inside and it's done !!
    15909554_1305909459483821_489230601_n.jpg 15870467_1305909466150487_306441989_n.jpg 15878766_1305909462817154_1054344626_n.jpg
  6. Meawto
    Thailand
    - 336Coins
    add this for 12v fan rpm control (speed by temperature)
  7. obobo
    obobo Active Member
    1,323Coins
    nice futur professionnal project ...
  8. lilted86
    lilted86 Member
    Malaysia
    489Coins
    awesome project!!!!!
  9. Meawto
    Thailand
    - 336Coins
    Better effect with TAKATA belt
  10. Meawto
    Thailand
    - 336Coins
    Update
    Replace U-joint hold with laser cut and new hole for box
  11. Meawto
    Thailand
    - 336Coins
    new update
    prepare for making long shoulder mount for better effect
    17357722_1886217271593436_286307579_o.jpg 17373010_1886217264926770_1070414537_o.jpg
  12. Meawto
    Thailand
    - 336Coins
    nearly finish :D
  13. bodgy
    bodgy Member
    Australia
    86Coins
    Nice electrical enclosure and great fabrication work! Looks like you are really putting some time and thought into the build.
  14. Meawto
    Thailand
    - 336Coins
    After a long weekend in thailand. finally i'm finish my work :)
    Test Video
  15. noorbeast
    153,890Coins
    +11,154 / 57 / -2
    Nice to see your rig in action, well done :thumbs
    In the video it seems the lever to rod angle is very acute, which is inefficient and strains the motors. About 40 degrees up and down from the lever being at a right angle to the rod is the most effective use of motor torque.
  16. Meawto
    Thailand
    - 336Coins
    hug:
    18199110_1451603988247700_473268700649814418_n.jpg 18221822_1451603968247702_6994202062733687488_n.jpg 18222335_1451603964914369_6774793796850278956_n.jpg 18268222_1451603984914367_2767781001363275436_n.jpg 18280986_1450468695027896_436417815_n.jpg
    and the old rod end
  17. Meawto
    Thailand
    - 336Coins
  18. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Hi ! Where did you buy your lever? How you have choose length? thanks :)
  19. noorbeast
    153,890Coins
    +11,154 / 57 / -2
    The lever is just steel and it should be robust, like 6mm thick, the length of a lever CTC depends on the design, power of the motor, load to be driven and desired speed, use the SimCalc tool to get an idea of the physics involved: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    How you build and attach levers depends on the type of motor shaft: https://www.xsimulator.net/community/faq/how-to-attach-levers-to-wormdrive-gearboxes.182/
  20. Meawto
    Thailand
    - 336Coins
    i made the levers from stainless steel ,sensor mount from aluminium and motors shaft connector to sensor by plastic
    19059973_1499024383505660_8588469058031449691_n.jpg 19060113_1499024360172329_6920757777505764465_n.jpg 18922054_1499024390172326_2425500961098640692_n.jpg 18952685_1499024386838993_2696032623180390533_n.jpg
