3-axis simulator: longitudinal - lateral - yaw
Discussion in 'DIY Motion Simulator Projects' started by gauthier, May 21, 2012.
  1. gauthier
    gauthier New Member
    VRP
    111Coins
    3DOF, SCN5
    Hi all,
    I have a simulator driven by two SCN5 and I want to add the effect of drift (yaw) with a third axis also powered by a SCN5.
    I have the 3 actuators. But I can not configuer x-Sim. When I add the effect YAW, the actuator does not respond properly. Has anyone already configured it under x-sim?
    Thank you for your help
  2. bsft
    Depends on the game, not every game the yaw effect works
  3. gauthier
    gauthier New Member
    VRP
    111Coins
    3DOF, SCN5
    hello,
    I play exclusively rfactor
  4. bsft
    You may have to fiddle with forces, try adding lateral to the drfit as well, but make it a BIG motion number, so it doesnt always shift you.
  5. bsft
    You may have to fiddle with forces, try adding lateral to the drift as well, but make it a BIG motion number, so it doesnt always shift you.
  6. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    You Must Wride a New axis in mathsetup in rfactor is it effect 32 and 36 i like the 36 more is the Yaw
    Aculation.than you Must Set the axis to the right scn in the outputsetup
  7. gauthier
    gauthier New Member
    VRP
    111Coins
    3DOF, SCN5
    effect 36 is very interresting!! thank you!
    But i don't unterstand than you Must Set the axis to the right scn in the outputsetup
