2DOF pneumatic simlator
Discussion in 'DIY Motion Simulator Projects' started by berty, Jan 5, 2015.
  1. berty
    berty Member
    164Coins
    Hi everyone,
    I would like to build a 2 Dof pneumatic simulator. I used the following pneumatic cylinders:
    http://www.ebay.com/itm/FESTO-CYLIN...ic_Hydraulic_Valves_Parts&hash=item3ceb403aee
    but I need advice, I'll be controlled via arduino with this board:
    http://www.ebay.com/itm/MODUDO-RELE...onenti_elettronici_attivi&hash=item3f2a180c35
    or use K8055 with this board: http://www.velleman.eu/products/view/?country=be&lang=en&id=361120
    When should I use the Arduino, so what code to insert?
    And even I would like to ask what the valves used to control pneumatic cylinders?
    Thank you.
    Sorry for my English.
  2. meo_udon
    meo_udon New Member
    691Coins
    Why you use pneumatic not electric motor?
  3. RacingMat
    21,082Coins
    The board you want to drive with Arduino have relays: ON/OFF.
    No progressive speed.
    Do you think it will be okay for your use?
  4. bsft
    K8055 is a good board for air rams
  5. Pit
    30,510Coins
    This is very interesting, @berty I would like to see and follow your progress. I hope you will get it!
    153,938Coins
    +11,158 / 57 / -2
    A real challenge in the making, it will be great to follow your progress.
  7. meo_udon
    meo_udon New Member
    691Coins
    I worry about sound noise level. In my shop have more pneumatic cylinder. Very loud.
  8. RacingMat
    21,082Coins
    +1 : I agree it's a drawback of pneumatic systems for home use
  9. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Found the same one on the Youtube :grin
    • Funny Funny x 2
  10. meo_udon
    meo_udon New Member
    691Coins
    I have 3 inches cylinder and airpump is 2HP 110 lites. Only 13 times open air to cylinder my pump will work again for 2 minutes.
  11. RacingMat
    21,082Coins
    @meo_udon
    how do you want to actuate forward and reverse with a single relay?
    I suppose that you intent to use several relays per actuator (thrust, exhaust... 4 relays?)
    Before writing any arduino code, you have to sketch the system: actuator, valves, exhausts, relays...
    we cannot guess what you have in mind ;)
  12. SeatTime
    Pneumatic cylinders normally have two air inlets - one to drive the actuator up - one to drive it down. Its going to become quite noisy, especially if your after small quick movements as required for a sim.
  13. meo_udon
    meo_udon New Member
    691Coins
    Ok some quesion. In two air inlet system. Have air drain or loss? In my cnc machine have two inlets when pnematic work. Air drain every time.
  14. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    I will be following the progress you make with this project, seems to be very interesting :thumbs
