Question 2dof motor arm angle...
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dgworks, Nov 2, 2021.
  1. dgworks
    dgworks New Member
    - 56Coins
    I'm building a 2 dof seat mover, and using solidworks to figure things out.
    However i run into a problem, wondering if the motor arm is designed to have a certain angle towards my ""ass""
    I do know the distance between holes are keys to speed and torque, and did use the tool to calculate.
    However, should i make it at a certain angle, or it is program configurable?
    thanks in advance
    154,726Coins
    +11,194 / 57 / -2
    Interesting mobile idea.
    A lever is most efficient at 90 degrees to what it is acting on, and effective torque utilisation drops off rapidly over about 38 degrees up and down.
    A compact design requires more torque than others, use Motion Visualizer and/or SimCalc to help get your head around the design Vs physics trade offs:
    Motion Visualizer: https://www.xsimulator.net/community/faq/motion-visualizer.389/
    SimCalc: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
