Question 2DOF Linear Traction Loss ( Yaw )
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Erik Green, Aug 29, 2022.
  1. Erik Green
    Erik Green Member
    321Coins
    Is there any reason a 2Dof Linear rig cannot output yaw?
    150,686Coins
    +11,018 / 55 / -2
    Yes, a standard 2DOF with a uni joint providing pitch, roll, sway, and simulated surge and heave, can't rotate or be controlled in the rotational Yaw axis, which be definition rotates around a center pivot.
    Yaw is a separate axis that would make the rig a 3DOF.
  3. Erik Green
    Erik Green Member
    321Coins
    Guess the better choice of term would have been pseudo Sway (not full lateral motion but rotation about the front fixed mount point). The 2 rear linear actuators can can be commanded to move in a lateral direction correct? When I select 2DOF Linear in Motion, how can I add Sway (rear traction loss?) as an input to Actuators 1 & 2.
    If I also add a single vertical D-Box style actuator to to the front of the rig I should be able to get true Heave as well as true Pitch motion, allowing more motion cue options than a traditional D-Box style rig?
