2DOF DRIVING SIMULATOR - SOLD
Discussion in 'Marketspace - Marktplatz' started by gigi, May 4, 2017.
  1. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    My second simulator is almost finished, titanic engagement, difficulty of every kind, but that's fine. I can do it and I will do it. Inevitable that two sim in the home can not stand. So I decided to sell my first realization, the Sim 2 dof. Made in nearly a year and a half of work and little at a time optimized to a very good level.The simulator was designed using only top-quality components, no low-powered scooters or low-end electronic cards, but I only repeat the first quality. Then 2 very powerful ZYT73 engines with gearbox 50: 1 powered by 2 600W 50A power supplies. Movement management is entrusted to two Pololu Jrk 12v12 cards, probably the fastest, most reliable and powerful cards in this power range, but also the most expensive Bourns potentiometers with hall sensor. The structure is made of appropriately dimensioned iron drawings and the main parts are bolted so that they can be dismantled if necessary. The electronic part is contained in a specially designed box and cooled by two fans. The steering wheel support is adjustable in height and depth, the pedal is adjustable in depth. The sim fits in heights between 140cm and 200cm. The sim is also predisposed for connecting a buttkicker gamer 2.The complete Sparco Rev2 seat delivery is in perfect condition and adjustable in its inclination thanks to its Omp brackets, 4-point Sparco seat belts and Fanatec V1 pedal. I'm not including steering wheel, gearbox, handbrake and pc. Which will eventually be sold separately but only at the same time as the sale of the sim. On the sim, you can of course install any Fanatec, Thrustmaster, Logitech G25 G27 or other base, idem for the pedal.
    Price request € 1.500,00.=
    Here are a couple of videos so you can understand how it works. If interested can contact me in pm. I will be delighted to give you more detailed info as well as make you try.
    gigi
  2. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    My rig was sold. thanks
