SimTools Presets 2DOF assetto corsa and p-cars
Discussion in 'Game Engine axes presets' started by zigzag49, Aug 26, 2015.
  1. zigzag49
    zigzag49 Active Member
    724Coins
    Configuring axes sway, surge, pitch, roll, heave on Assetto games and p-cars and min/max tuning center.
  2. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
  3. Nick Moxley
    17,057Coins
    I cant see accessing much Heave data with a 5, Can i suggest you Try lowering to 3 or even 2.5 you might be surprised the data your missing from the Awesome Assetto Laser scans, that is Distinctively missing from Pcars track mesh's. ;)
  4. zigzag49
    724Coins
    Atlas974 thank you .
    Nick Moxley I will test to heave and you repeated.
    152,640Coins
    +11,087 / 56 / -2
    Sometimes heave needs a value less than 1 for the full effect and if so you can manually enter values like 0.9, all the way down to 0.001
  6. Nick Moxley
    17,057Coins
    Be warned, Stiff race cars like F1 or Single seaters, and even GT2/Prototype cars will have a VERY pronounced heave effect due to the stiffly dampened suspension. be careful HOW low you actually take the Tuning center #'s.
  7. Nick Moxley
    17,057Coins
    Here's an example of how dampers on a Stiff Single seater can react with 0 on the profiler followed by -50 on the profiler and finally a damper fix provided to me by my "Suspension master MisterBeam aka Karim"
  8. bsft
    Unless I am wrong he is using and ard and wipers, so good luck getting decent heave motion
  9. zigzag49
    724Coins
    Thank you advice.
    BSFT sorry I did not understand the translation ;)
  10. bsft
    @zigzag49 . i see you use and arduino for motor control, but what motors do you use?
  11. zigzag49
    724Coins
    Ce sont des moteurs 24v d'essuie glace poids lourd de récupération, je n'en connaît pas les spécificités.
    Tester le heave à 3 en min/max dans tuning center à 90% de force sans filtre , sa secoue pas mal ( trop ).
    Baisser aussi roll et pitch à 25 min/max et 50 % de force pour les deux , c'est beaucoup moin prononcer.
    Tout ça sur AC , je partagerai mes réglage une fois convenable;)
    They are 24v engines windshield ice truck recovery, I do not know the specifics. Test heave to 3 min / max tuning center in 90% strength without filter, its not shakes a lot (too much). Lower roll and pitch as 25 min / max and 50% for both strength is much moin pronounce.
    All on AC, I will share my settings when appropriate
  12. bsft
    Wipers normally run about 50-60 rpm, so if they are 24v wipers and you are running them at 24v, then you have about 50 rpm.
    On the other hand, if you run 12v through a 24v motor, you halve the speed, so its more like 25-30 rpm.
    @Nick Moxley is using 160 rpm motors at 12v.
    So the speed difference will never be matched by wipers.
    Sorry.
  13. zigzag49
    724Coins
    Ok je revoit quelques réglage et vous en fait pars.
    Ok I shall review some setting and you actually go.
  14. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    j attend avec impatience s'est le t1000 que tu as?
    I can not wait The t1000 is that you?
  15. zigzag49
    724Coins
    A non je n'es pas le T1000 , c'est fabrication maison , mais c'est flateur:D
    A no I are not the T1000, it's homemade, but it is flattering:D
  16. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    du coup tes réglages ne me servent pas a grand chose :rolleyes: mais merci pour le partage d'info :thumbs
    suddenly your settings do not serve me much:rolleyes: but thank you for the info sharing:thumbs
  17. bsft
    you would be better creating your own, or using a JRK 200 watt DC motor shared profile
    But really, do your own.
  18. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    hi @Nick Moxley can you share more about this dumper fix.
    i really like this car and see your setup is great with motion.
    finally i have figured out with profiles and i am enjoying playing even more now:grin.
  19. MiNeM
    MiNeM ..........
    Self Employed
    Johannesburg
    333Coins
    Thank you will try these before i get the plugins :)
  20. bsft
    @MiNeM , your coins count has been updated and drop f1iceman and nclabs a line to help get your rig set up with SCNs
